New Billet Turbo Pics For Your Enjoyment!
Old Aug 21, 2014 | 08:24 PM
TommiM's Avatar
Originally Posted by MIR Engineering
The 12k each is for cars like promods or extreme 10.5 cars making 4k hp. It actually says that on the page. The 12k each is priced the same as the other high end promod units.....
Our performance dual ball bearing units that would go on a car like a EVO, come with our billet cover, billet comp wheel and a stainless turbine housing with either vband or t3 inlet in the low 2k range.
Variable vane geometry, ball bearing turbo, bolts to oem manifold and oem style downpipe, for low 2k range sounds promising.
Old Aug 21, 2014 | 08:32 PM
MIR Engineering's Avatar
Originally Posted by Dallas J
Look like you guys need a little pencil line finishing .
Pretty rad, CNC **** keeps me up those long hours!
Yes, we know all about the long hours! haha! Putting in 16 hour days to bring this baby to the world!
Old Aug 21, 2014 | 08:33 PM
Originally Posted by tommim
variable vane geometry, ball bearing turbo, bolts to oem manifold and oem style downpipe, for low 2k range sounds promising.
yes sir!
Old Aug 22, 2014 | 11:31 AM
We should have some more updates some time today on the Turbo assembly that is coming together!!
Old Aug 22, 2014 | 01:40 PM
This may help explain a little bit more about some of the questions that you all have!
http://makeitrightengineering.com/Th...er-Technology/
Old Aug 22, 2014 | 02:46 PM
mitsubeastlee's Avatar
waiting for end result...
Old Aug 22, 2014 | 03:19 PM
Won't be too much longer! We are putting in long hours in R&D to bring these bad boys to the public!
Old Aug 23, 2014 | 07:23 AM
TommiM's Avatar
yes sir!
Sweet. Curious, since you are able to do all this. What about built in bpv, and wheel speed sensors like what Borg Warner is doing, is that possible?
From a technical aspect, what differences are there to do variable vane geometries on a compressor side versus turbine side? I just noticed that on performance orientated stuff Ive seen the variable vanes focusing on the compressor wheels, while stuff like oem diesel applications have it on the turbine side. As one example, the Mercedes OM642 diesel has an electric solenoid that will engage or disengage the variable fins on the turbine wheel to vary boost pressures.
Old Aug 23, 2014 | 10:56 AM
Yes, we are planning both of the built in bpv, and wheel speed sensors, as far as the Variable vein on the compressor side, not as of now.
Old Aug 23, 2014 | 10:59 AM
deylag's Avatar
You have my interest.
Old Aug 23, 2014 | 11:40 AM
Good to hear!
Old Aug 23, 2014 | 02:51 PM
way2qik's Avatar
Designing parts to be a cast has certain limitations and doesn't always allow the freedoms needed in order to design the best performing part.
That sure looks an awful lot like a copy of a Garrett GTX wheel.
Old Aug 25, 2014 | 09:20 PM
CO_VR4's Avatar
So now I read that you're using Garrett center sections, not making your own billet versions. Someone else said your compressor wheel looks like the Garret GTX...
I asked you days ago the following question:
"As far as billet wheels go, anyone with a Renishaw probe can reverse engineer any wheel that they can get an original of. That's happened before on billet wheels in Evolution fit turbos. What's different about your wheel than the ones out there now?"
So, is the compressor wheel you are planning to use a copy of someone else's wheel, like other "new" turbos were a year or two ago? If they're not reverse engineered from Garrett or FP, what's different about yours as compared to theirs?
Old Aug 27, 2014 | 03:31 PM
EvoDan2004's Avatar
Guess my first post was correct.
How do you expect us to pay 2500.00 for a Garrett turbo? LOL
I saw the FB pics. Identical to a GTX turbo.
Old Aug 27, 2014 | 05:14 PM
211Ratsbud's Avatar
/the end
