help?
Old Sep 4, 2014 | 04:27 AM
KnightX's Avatar
help?
Hey guys.. I've never posted here b4 but lastnight I ran into a problem with my 2005 Evo 8 that made me have the worst sleep of my life..
when I first turned this thing with just
Intake, Upper/Lower Intercooler piping and 3" catback I made
325/350
After I upgraded the turbo (GT3076R) and changed into "coil on pack" system
I put down 349/312
After that I upgraded to ID1000cc, cause the tuner said I was leaning out
I put down 375/347
he then told me to change the fuel pump cause I was leaning out after 6k
1 week after the last tune (injectors) I went back in lastnight with a Walbro 255 fuel pump
I put down 317/287
we are lost... did a compression test 150/175/150/175 all across
changed the plugs - same thing
changed the coils - same thing
car is still hitting peek boost so we know its not the turbo
clutch is ok, never slipped once on the dyno
he told me to get a fuel pressure gauge and change it to a 4Bar map to see if this would help... I don't want to keep dumping money into it without knowing where the problem is... IM NOW SLOWER THEN WHEN I WAS STOCK!!!
any idea guys? input?
Old Sep 4, 2014 | 11:33 AM
Bhsj13's Avatar
the fpr messed up?
Old Sep 4, 2014 | 12:38 PM
andrewzaragoza's Avatar
check for boost leak. fuel pressure gauge shouldn't be needed as long as the afr is correct during the runs.
Old Sep 4, 2014 | 03:04 PM
KnightX's Avatar
I don't have an aftermarket FPR on the car yet and it's using the stock one on the rail. Hance why he told me to get a fule pressure gauge just to tap into the line to make sure the car is getting the proper fuel
Eartears
23
Mar 1, 2017 11:53 AM
xhammerx
Oct 1, 2010 08:05 PM
LSs1Power
Nov 27, 2005 06:57 PM
