eBay o2 housings: Once they crack weld or replace?
Old Sep 9, 2014 | 07:04 AM
e_kobz's Avatar
Originally Posted by slowsrt4:(
get a new one and consider an o2 dump. MUSE makes a great affordable one.
Read posts 5 - 8
Old Sep 9, 2014 | 09:31 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Originally Posted by Nimpoc
I'd done this previously and sailed through smog check:
https://www.evolutionm.net/forums/me...sses-9509.html
We do have a number of great tracks around here. The other downside of the dump I forgot about is Laguna. My current set-up is 90.8dB which means I can run at any event. That's what's kept me from trying the Road Race Engineering / English style exhaust cutout.
https://www.evolutionm.net/forums/pa...pipe-dump.html
For less noise/attention I run this:
http://store.worksmotorsports.com/WO..._p/147.106.htm
I hadn't thought about welding something to allow for the stock heat shield. It's pretty buried in there though, do you think someone would be able to see it if it's flat black?
Old Sep 9, 2014 | 08:04 PM
xXANCHORMONXx's Avatar
Invidia is huge, I don't recommend it for anyone under 400whp, its a pia to install, o2 sensor needs to be extended as well.
http://www.streettunedmotorsports.co...o2_housing.htm
This would work
Old Sep 10, 2014 | 09:37 AM
Nimpoc's Avatar
This would work
That's what I had and cracked it...
To be replaced with this other same-as-MAP one:
https://www.evolutionm.net/forums/ve...evo-8-9-a.html
Old Sep 10, 2014 | 10:47 AM
Nimpoc's Avatar
Even with the heat shield in place you could catch a glimpse of the o2 housing if you knew what to look for. Smog guy missed it though. Painting black + heat shield would be invisible.
For me the heat shield is as much about protecting the AC compressor & PS pump as anything.
Old Sep 10, 2014 | 11:08 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Ah, good point. I'll have to steal your idea and have some bungs welded up.
Any idea on thread size?
EGbeater
Jul 23, 2016 08:16 AM
Nimpoc
Sep 22, 2015 11:49 PM
Huge
For Sale - Cars For Sale
Jul 19, 2015 02:29 PM
Nimpoc
Jan 23, 2015 12:19 AM
MitsuEvo1
Nov 7, 2010 10:27 AM
