broken spark plug tip why? scortched pistons too?
Old Sep 8, 2014 | 08:29 AM
CT9A PR's Avatar
Car had r2 with kiggly spring with retainer
Old Sep 8, 2014 | 08:36 AM
jjuntho's Avatar
Rod bolts loose and piston hit the spark plug tip ,be sure pull out the oil pan and check the rod bolts before install new spark plugs.
Old Sep 8, 2014 | 08:38 AM
CT9A PR's Avatar
Old Sep 8, 2014 | 08:45 AM
CrusifiX's Avatar
I've never seen a piston melted so entirely like that on a street car before...
Old Sep 8, 2014 | 08:51 AM
CT9A PR's Avatar
Its not melted its metal on metal valve dropped too
Old Sep 8, 2014 | 08:53 AM
jjuntho's Avatar
My engine also look like that and my was a rod bolts broke and the piston hit the spark plug and destroy my engine I was running 30 psi e85 with new turbo kit ATP gtx3076r I has almost 40000 miles on the new set up before rod bolt give up
CrusifiX's Avatar
That makes the pics make more sense to me. Looking at it from my iphone it looked melted, LOL.
Old Sep 9, 2014 | 08:48 AM
mrfred's Avatar
question is what broke first...
Old Sep 9, 2014 | 10:59 AM
counterforce661's Avatar
Wow, that is painful to look at!
Old Sep 9, 2014 | 11:21 AM
Migsubishi's Avatar
Wow, was this the engine at 51psi and 125 shot nitrous?
Here is what I have seen happen, first who tuned it?
I have seen a cylinder get hot and detonate so bad that it burnt the ground strap off the plug, the metal bounced around in the cylinder before getting caught by the valve trying to close. This in turns breaks the valve causing it to drop into the cylinder. At this point the valve gets pounded to death between the head and piston ultimately putting a hole in the piston and destroying the engine.
I have also seen this happen when people install bigger cams w/o checking clearances after the fact before running the engine.
Old Sep 9, 2014 | 06:13 PM
JohnBradley's Avatar
#2 doesnt look burned up so I'd presume the tune was okay and this was hardware failure of some kind. What rpm was it at when it failed?
Old Sep 9, 2014 | 06:15 PM
xXANCHORMONXx's Avatar
Looks like some rolled up aluminum foil and threw it in there. Sorry for your loss
Old Sep 9, 2014 | 07:35 PM
CT9A PR's Avatar
No ef3 engine
Old Sep 9, 2014 | 07:37 PM
CT9A PR's Avatar
He was reving to 8250 on. 2.1L
Guy is ok with his loss but I just am shocked by this and wanted to be sure
Old Sep 9, 2014 | 07:38 PM
Migsubishi's Avatar
Originally Posted by CT9A PR
No ef3 engine
Damn, sorry about your loss man.
DjMarcus
08+ Lancer Show / Shine
Aug 31, 2012 01:42 PM
ApexEVoIX03
50
Jan 5, 2012 03:41 PM
raytrix
Jul 27, 2010 05:17 AM
teddyshooter
Jul 7, 2009 12:22 AM
il2az
Aug 2, 2006 12:35 AM
