Battery voltage
Old Sep 10, 2014 | 01:05 PM
evo9shane's Avatar
Question Battery voltage
SO I HAD TO STOP SUDDENLY TODAY AND WHEN I DID MY BATTERY LIGHT CAME ON AND ALL MY GAUGES AND LIGHTS STOPPED WORKING. THE ENGINE STARTED TO HOLD AN IDLE OF 2000 RPMS. I GOT IT HOME AND NOW WHEN I TRY TO START IT JUST CLICKS. NO CHECK ENGINE LIGHT OR CODES ON MY READER
P.S. I HAD MY S-BELT REPLACED YESTERDAY AT FIRSTONE AND THEY SAID THEY WONT BE ABLE TO DO MUCH LOOKING INTO IT BECAUSE OF THE MOD'S TO THE CAR.
ANY IDEAS WHAT THE PROBLEM COULD BE??
Old Sep 10, 2014 | 05:58 PM
iD33's Avatar
The drive belt/power steering belt may have dislodged from a pulley. If the belt is still intact check for tension. Another possibility could be the power wire going to the alternator is loose, though i seriously doubt it. Those monkeys at Firestone
Old Sep 10, 2014 | 07:41 PM
evo9shane's Avatar
the tension is still good and connections are fine. i jumped it and as soon as i took off the cables the battery voltage dropped down to 7.4 on my turbo timer gauge.
Old Sep 10, 2014 | 09:47 PM
TommiM's Avatar
Possible voltage drop somewhere. Do you have a relocated battery by chance? You might also have a charging system issue. Its possible your alternator is going out. Its gonna be hard to diagnose over the internet. Are you mechanically inclined enough to use a multi meter?
Old Sep 10, 2014 | 09:58 PM
evo9shane's Avatar
yes im just confused where to start, im guessing alternator having it checked tomorrow but when running voltage doesnt go over 9 or 10 volts when normally its about 14
Jovan Caro
Jan 30, 2017 11:19 AM
mnewdigate
Lancer Troubleshooting
10
Apr 24, 2016 11:25 AM
RxRA
10
Nov 25, 2012 10:21 AM
McDougal
Jun 26, 2012 08:37 PM
Newuser213
Lancer Engine Tech
Jun 8, 2011 01:33 PM
