Exhaust valve leak
Old Sep 14, 2014 | 11:18 PM
dvsrome's Avatar
Exhaust valve leak
Hey everyone I have an 8 with most boltons. I am upgrading to gsc s2 cams and a ef2 map turbo. We did a compression test and leakdown. The leakdown had 5% in cylinders 1-3 and 12% in #4. Should I replace my valves or do you think it will be ok.
Old Sep 15, 2014 | 08:28 AM
jspecteggy's Avatar
I would just have a trusted machine shop do a valve job on the head..cleans up the mating surfaces between the valve and valve seat and is usually cheaper than new valves
Old Sep 15, 2014 | 10:34 AM
dvsrome's Avatar
If I pull the head I'm going new valves since I am putting in new springs and retainers. My tuner says leave the valves but my mechAnic says replace them. Trying to figure out if the mechanic is doing it for the extra money.
Old Sep 17, 2014 | 07:48 AM
jspecteggy's Avatar
Well leaking valves are a bad thing. The mechanic may just not want to give back an engine like that but he can also be just trying to squeeze you for some extra money if he's taking off the head and you're not taking it off yourself. I would personally just remove the head myself and get them reseated.
Old Sep 18, 2014 | 10:51 AM
slowsrt4:('s Avatar
If you're in there you might as well go with bigger valves and new valve seats.
Old Sep 18, 2014 | 11:29 AM
meckert's Avatar
12% isn't enough to bother with, drop your cams in... You may never have an issue-- and its not always the valves that cause compression leakage-. Only way to tell is pull the head. Drive it and when it goes---then do the valve job and anything else.
Old Sep 18, 2014 | 02:40 PM
superbovine's Avatar
That right there.
12% is still fine, typically the rule of thumb is over 20% is when you need to get in there and see whats up. For all you know it could be a ring too.
Granted we all want 5brazilian HP evos and everything top notch and only date 10's etc, but real world numbers it is fine if your compression is level.
If you had a significant compression number variation because of it, that could be cause for work, but you didn't mention that.
liass44
17
Sep 28, 2016 01:48 PM
ctfpevoVIII
Jul 12, 2015 07:07 AM
1fast97gsx
16
Feb 2, 2015 01:11 AM
Chukee_R
Feb 26, 2008 06:05 AM
Bster13
Sep 5, 2007 12:17 PM
