Holset powered EVO 4
Old Sep 17, 2014 | 09:48 AM
stunt2's Avatar
Wink Holset powered EVO 4
don't know if it's the right section for such thread. if not - mods please move it to corresponding section
so, shortly about the car: it's an jdm evo 4 GSR
engine is 2.3L: it was rebored to 86mm and built with Wiseco 9.0:1 stroker pistons, mitsu 100mm crank, manley 150mm rods and ACL race series beraings, balance shaft deleted
head: it's unported with oem intake manifold. just ARP's, uprated valve springs and retainers and GSC S2 cams
fuel: wallbro 255 hardwired, FIC950's, DIY COP kit
ecu: evo 8
trasnmission: oem clutch/tranny/t-case. rear diff - AYC deleted and installed RS LSD diff
handling: HKS Hipermax PRO coilovers 12K/12K. evo VI TME quick steering rack, EVO VI brembos all around
some pics of the car
(sorry for cell phone pics)
фотохостинг png
Old Sep 17, 2014 | 09:57 AM
stunt2's Avatar
all began when I bought brand new genuine Holset HX35 on ebay for 280$
the only downside was that it turned out with 14cm twinscroll T3 housing, instead of 12cm one, which I wanted
billet wheel ?
Old Sep 17, 2014 | 10:18 AM
stunt2's Avatar
as no off the shelf manifold for this turbo on evo 4, we made custom twin scroll manifold. decided to go low mount setup with twin Tial 38mm wastegates, while remaining AC, and oem radiator. could be remained oem fan as well but it was the first 4G63 manifold for the welder and made a small mistake in measurements. It came out tight fit but all in all, went on it's place
coated with hight temp paint. first layer
second layer
Old Sep 17, 2014 | 11:17 AM
94AWDcoupe's Avatar
the hx35 12cm TS is one of the best "cheap" turbos to run a 2L engine. seen many very pretty dynographs at 500whp with very quick spool. the 14cm should work very well on the 2.3.
Old Sep 28, 2014 | 03:32 PM
physicsgeek's Avatar
Ok sorry to ask a seriously newbie question but I can't seem to find any advise in my search. I am looking to turbo my 4g64 2.4l and I was wondering. How do you decide what size waste gate to use? I am going to build a manifold so I can design accordingly.
Old Sep 28, 2014 | 11:40 PM
stunt2's Avatar
was going to use single 44mm one but manifold design, fitment etc. didn't allow us to join two discharge pipes and then fit 44mm wg
so we went with twin 38mm ones
Old Sep 28, 2014 | 11:46 PM
stunt2's Avatar
some spool-up log
4th gear wot from 2500
hits 30 psi at 4000 rpm
фотохостинг
Thero
Dec 13, 2015 10:02 PM
JukEboXAuDiO
Jan 21, 2015 05:37 AM
REV.olution
Jan 12, 2015 08:23 AM
honda-guy
Aug 10, 2014 02:51 AM
dw cuz
Jun 16, 2014 12:37 PM
