Mivec Feed Line Banjo Bolt Leak
The factory specified torque is 22 ft-lb, but tbh I just tightened the bolt bit by bit until it stopped leaking. 22 ft lb is way too much for that piece of S*** bolt... Also, those things are essentially one time use. I think that they just get so fatigued from all of the vibrations, and then when you put torque on it to take it back out it must weaken it significantly. I have snapped every single damn bolt that I have tried to re-use. Ridiculous.
Alright there ya little fetuses! So I finally got around to updating this thread, but in case anybody has this problem in the future, I ended up sealing my leak up using some pressure sealing washers. I got mine from McMaster (http://www.mcmaster.com/#93786a200/=u4fhxf). Put them on initially and it didn't quite seal which PISSED me off, but I tightened it up a little bit today and just went for a drive and when I got back everything was dry! EFFIN HAIL SATAN!!! Thanks for the tips from everyone on the forum, you guys are my best hoes.
Ok so bad news.... It wouldn't stop leaking so I kept tightening the bolt until it snapped.... How did you get the broken end of the banjo bolt out of the block with the motor in the car? Not a lot of room to work with. Please help.
I really don't think that was the problem.
When I snapped them off, I think I was able to get them out with a needle-nosed pliers. You could also buy an extractor tool. Something like in the link below.
http://www.harborfreight.com/screw-e...-pc-61981.html
If the rubberized sealing washers aren't working for you, I don't know what to tell ya. Maybe try putting some RTV on it. Make sure you use new crush washers too.
Bumping an old thread because I just tried something. I took the advice of somebody above and taped to the banjo bolt with a hammer after I torqued it. I didn't hit it very much just a light tap. Afterwards I went to recheck the torque on the bolt, and it turned a very small amount after. I think tapping it to seat the washer was a good idea.
I had a leak here previously, we'll see how it goes now. To reiterate: I torqued The banjo bolt, tapped slightly with a hammer, then retorqued. I had no idea banjo bolt would need retorquing afterward.
TURBODAWG
10
Mar 17, 2018 04:04 AM
Grimgrak
Sep 14, 2015 07:48 PM
J8dailo
Apr 1, 2009 04:10 PM
