Dyno results 369.9 whp / 347.5 tq
Just what the subject says!
http://www.liquidice.net/evo/dyno.htm
Done on an AWD Dynapack, 4th gear, 93 octane, 21 psi at
http://www.redshiftmotorsports.com
Next step, some more fine tuning and adjusting my cam gears!
Nice numbers.
What kind of gas? How much boost?
It seems like the 272 guys are making better numbers on the stock turbo than the 264. Everyone else seemed to say that the difference is negligible. How is your idle?
Edit: Just saw that it was made on 93 octane. Sweet.
Tranny is like butta! Props to John Sheperd.
Those pulls were done at 21psi. About 11.8-12:1 afr.
Idle is nice at 800-900 sounds mean as hell!
I'm pretty impressed with those numbers since I was hoping to see 340whp.
Re: Dyno results 369.9 whp / 347.5 tq
Originally posted by smackdaddy
Done on an AWD Dynojet, 4th gear, 93 octane, 21 psi at
I will be up at RedShift this week sometime to take a few Dyno pulls and a few adjustments to the Emanage.
evo dyno
We did change fueling a little bit to be safe. We did a few runs that were cut short because of high 13 a/f ratios at full boost. That Evo is one of the best sounding cars I've ever heard. Looking forward to have it back someday.
Oh, and btw, the dyno we use is a Dynapack, not a Dynojet. The power he saw was real power, without the help of long sweep times or artificial sae correction. If I'm not mistaken, the SAE correction was only 2% or so.... very much within the range of being accurate and reasonable and as SAE intended.
Congrats on a good setup so far.
Chris
Chris
