Which transmission fluid?
Old Nov 10, 2014 | 05:32 PM
apagan01's Avatar
Diaqueen a mineral oil. Breaks down faster and lubrication is inferior to a synthetic.
Amsoil full synthetic. Last longer, lubrication is always there for thr tranny when most needed under high loads and high heat
Old Nov 10, 2014 | 05:38 PM
Luisaleman123's Avatar
I did oem but going to try amsoil next time heard good things
Old Nov 11, 2014 | 07:41 AM
thepoint4life23's Avatar
Any one know what shep says to run in his stage one trans?
Old Nov 11, 2014 | 09:12 AM
e_kobz's Avatar
My guess is Redline cause thats what he sells
Old Nov 11, 2014 | 09:13 AM
e_kobz's Avatar
I follow this
http://www.teamrip.com/manual_transm...tion_info.html
Old Nov 11, 2014 | 08:01 PM
AJCaron12's Avatar
This wasn't on that list, has anybody used this before?http://www.streettunedmotorsports.co...box_100099.htm
Old Nov 12, 2014 | 09:16 AM
GravityKnight's Avatar
There is more to a manual transmission fluid than just how good/long lasting the fluid is (synthetic). Find me a synthetic that shifts as good as the OEM fluid and I'll be interested. (and I'm not talking about in -25 deg weather when the fluid isn't warmed up... under normal conditions, find me a synthetic that beats OEM). Synchros need the right kind of fluid to operate properly. Many things just don't cut it there, or are too slick.
I don't have experience wth the 6 speed, but for the 5.. Diaqueen is the best I've found and I've tried several different things and combinations. MT-90 is the best synthetic I've found, but the shift quality of OEM fluid is the best. It was the same with the STI 6 speed I put in my wrx, oem Subaru Extra-S could not be beat. From what I've read the 6 speed in the evo's is no different. Same with the rear diff, run mitsu lsd oil unless you have an aftermarket rear diff that specifies something else.
Old Nov 12, 2014 | 11:51 AM
Thats why i asked what shep says to run i ran a coocktail of two different red-lines in my car now and i feel it is not shifting as smooth as what was in it before
Old Nov 12, 2014 | 12:30 PM
I've had good luck with 2 quarts of diaqueen and 1 quart of mt-90. You could probably substitute the redline for another quality synthetic gear oil as well. Helps in cold weather and may provide some of the benefits of synthetic while still retaining the shift quality of oem fluid. But I have no reason to believe the oem fluid is not quality/long life. This isn't just coming from me/my limited experiance- I'm good friends with Jack/Kevin from Jack's transmissions and they have tried everything.
And built trannies still use basically oem parts, so the fluid choice/requirements are not really going to change.
And even if the $20/quart oem fluid has to be changed more often, so be it- I think it's worth it for the shift quality.
But that's my opinion, others may have found different results.
Old Nov 19, 2014 | 07:35 AM
apagan01's Avatar
Originally Posted by jfvhpilot
Fortunately, my transmission was not noisy. Amsoil definately made it shift better.
Good feedback...
Old Nov 19, 2014 | 07:41 AM
apagan01's Avatar
Your experience is very oposite than what I had... i had a GSR IX 5speed of course and the diaqueen was not working for me under cold weather I mean 50-70 degrees this is cold for us here in Florida.. it was not working for my fast shifting habits either.... i had a friend that was the master mechanic at mistu and he swapped the fluid for the 6spd tranny fluid... no good either.. i was frustrated found amsoil and switched to them what a night and day difference even when I switched stock clutch to the ACT clutch which are known for no sifting right my tranny was smoth.
Old Nov 19, 2014 | 12:34 PM
...well I would expect the AMSOIL dealer to have good results with AMSOIL
Nothing against AMSOIL... I've used it for years in many applications. There are also several other quality oil brands that are every bit as good and in some cases better.
Anyway I am giving an unbiased opinion... I don't get anything out of people using OEM fluid. But my own experience favors it, and the guys who build these transmissions and have done more testing than you can imagine also recommend it.
Hey if it works, run it. Seriously, I'm not telling people not to run AMSOIL, about the only thing I would caution people not to run is synchromesh... but to anyone who is not happy with the way their trans shifts, don't assume you have to run an aftermarket fluid, this is one of those places where the fluid designed to work in your trans... actually works well.
Old Jul 18, 2015 | 11:02 PM
wjamyers's Avatar
I just switched from straight Redline MT-90 to the cocktail, 2 Quarts Redline MT-90 + 1 Quart of Redline MTL (on Advice from Moore Automotive) and my shifting seems much improved. All the notchiness and grind that happened occasionally with straight MT-90 is completely gone in the past 2 days of driving around town. Effing brilliant. Seems like the solution for me.
EvilDSM97
Jul 16, 2016 06:10 PM
a2b
Nov 14, 2012 12:33 PM
konstantinosIX
17
Jun 1, 2008 12:32 AM
Freddie1111
Nov 23, 2004 11:44 AM
