Which transmission fluid?
Old Nov 8, 2014 | 10:17 AM
AJCaron12's Avatar
Which transmission fluid do you recommend to quiet down a noisy/humming 6spd transmission? I have OEM Diaqueen in it right now, I've heard Amsoil might be a better alternative to quiet it down a bit.
Old Nov 8, 2014 | 10:23 AM
e_kobz's Avatar
For the 6 speed transmission just stick with the OEM Diaqueen
Old Nov 8, 2014 | 11:41 AM
zentac's Avatar
I only run MOTUL gear. Never had any issues.
Old Nov 8, 2014 | 11:48 AM
e_kobz's Avatar
I too run Motul in my 5 Speed.
Old Nov 8, 2014 | 01:01 PM
AJCaron12's Avatar
I have a 6spd, not 5spd.
Old Nov 8, 2014 | 01:03 PM
zentac's Avatar
Didn't matter still good oil.
Old Nov 8, 2014 | 01:06 PM
Kreeker's Avatar
I'm thinking of switching back to diaqueen. Both amsoil and redline are so notchy at start-up
Old Nov 8, 2014 | 03:44 PM
AJCaron12's Avatar
My Diaqueen is a bit notchy at startup too. I usually let the car run for about 7 mins before I take off.
Old Nov 8, 2014 | 03:48 PM
e_kobz's Avatar
I aware hence why I suggested you replace it with OEM Diaqueen.
Old Nov 8, 2014 | 04:00 PM
AJCaron12's Avatar
I'm already using OEM Diaqueen, I've stated that 3 times. I'm wondering what aftermarket fluid is out there that will quiet the transmission down a little? Maybe your statement has confused me.
Old Nov 8, 2014 | 04:04 PM
e_kobz's Avatar
Read posts #5 and #6
https://www.evolutionm.net/forums/ev...id-change.html
Old Nov 8, 2014 | 04:49 PM
jfvhpilot's Avatar
T oil
I recently put Amsoil in my 06 MR. It definately shifts smoother.
Old Nov 8, 2014 | 05:15 PM
AJCaron12's Avatar
What about noise? I'm mostly concerned with a noise issue.
Old Nov 8, 2014 | 05:31 PM
ak47po's Avatar
If it ain't broke don't fix it... Diaqueen
Old Nov 9, 2014 | 06:22 AM
jfvhpilot's Avatar
Amsoil
Fortunately, my transmission was not noisy. Amsoil definately made it shift better.
