What diff oil I should be running ?
In all reality, you probably want to run OEM if you just have rearranged plates.
96-07 EVO: Mitsubishi recommends that the rear axle that is found in the EVOLUTION be filled with their factory oil, Diaqueen LSD Gear Oil part# 3775610 or a high quality GL-5 or higher 90w Hypoid LSD gear oil. These oils contain a friction modifier that will reduce noise associated with friction disc type limited slips.
REDLINE 80W-140 GL-5 GEAR OIL We recommend using Redline 80W140 GL-5 Gear Oil. Their part number is # 58104. For road racing applications, use Redline 80w-140.
REDLINE SHOCKPROOF HEAVY If the vehicle is going to be drag raced Redline Shockproof Heavy is an excellent oil for the rear axle but outside temps should be 45*F or warmer because the oil is not thin enough for cold weather use.
Like everyone else's Evo, my car came with the factory fill Diaqueen in the rear diff. From day one the rear diff exhibited an annoying whine while slowing for a red light, during deceleration with the throttle lifted.
I dumped the Diaqueen at 30,000 kilometers and replaced it with Competition ff Motul and no more whining and gnashing upon deceleration.
Chrushev
Nov 12, 2016 09:32 AM
black-dsm
Sep 5, 2012 12:44 PM
Kwman
Mar 16, 2005 03:26 PM
