i just drained the oil and....
Old Nov 19, 2014 | 02:38 PM
Jonno99's Avatar
so i am doing an oil change, this is my first one and i drained the oil into an old oil container, so isnt the evo 9 sump suppose to hold around 5.3 litres?...well the total oil i got out of it came to around 4 litres....and i checked the dip stick before i drained it and it seemed full. Is there oil normally sitting in the engine that hasnt come out or is this normal? Oh by the way this oil includes the oil filter oil too as i dropped that oil out too. Anddd i jacked up the car just enough to get my hand under drop out the sump plug so its not sitting up on ramps, its pretty flat.
Old Nov 19, 2014 | 02:41 PM
Ev0ikon's Avatar
You gotta flip the car up-side-down and then drill the oil cooler to get all of it out.
Old Nov 19, 2014 | 03:13 PM
Raptord's Avatar
The filter has absorbed some, and there's some in the oil cooler that won't all drain out. I always drain less than what I put back in as well, no worries.
Old Nov 19, 2014 | 03:21 PM
LetsGetThisDone's Avatar
Oil filter holds about 8-10oz. And you have some in the oil cooler..
Old Nov 19, 2014 | 03:36 PM
Jonno99's Avatar
is it possible to get the oil cooler drained or do i have to put up with old oil mixing in with my good stuff when i fill it back up?
Old Nov 19, 2014 | 03:40 PM
RallySport9's Avatar
Thread should be titled "so I just drained the oil and....everything looked fine"
Old Nov 19, 2014 | 03:45 PM
You could take a line off. Not really worth it IMO. Most of it should come out of the filter housing.
Old Nov 19, 2014 | 05:43 PM
Jonno99's Avatar
i let it stand over night and got a furher couple of cup fulls out...it took 5 litres exactly, so I still have .3 litres of black mixing in. it would be nice to be able to hand crank the engine and push the rest out of the cooler
Old Nov 19, 2014 | 06:58 PM
You're way to concerned about it IMO. I just drain it, remove filter, let drain for 30 mintes, pour a quart of new cheap oil through it with the drain plug out. Then replace the filter plug it up and fill it. My oil stays fairly clear/gold for over 500 miles..
rvaldez4
Jul 23, 2013 08:38 PM
01 Trans-Am WS6
Jul 24, 2010 06:49 PM
dustin11
Mar 15, 2009 09:46 AM
RalliArtEvoVIII
Dec 14, 2004 09:33 PM
