What mounting hardware for FP Manifold
Old Feb 6, 2018 | 04:41 PM
EvoIIIAj's Avatar
Originally Posted by Fast_Freddie
All stuff was ordered from Jegs and drop shipped from ARP...
ARP 300-8343 Replacement Nut x2 Jegs PN 070-300-8343 $4.00
12-Point Nut
Black Oxide
M10 x 1.25 Small Collar
12mm Socket Size
1 per pkg
ARP 663-1010 Bulk Metric Thread Chromemoly Bolts 80mm(pack of 5) Jegs PN 070-663-1010 $18.22
Black Oxide
M10 x 1.25
80mm UHL
Subtotal: $26.22
FREE Handling: $0.00
FREE Shipping: $0.00
Total: $26.22
Sorry to revive this, but won’t you need 2 studs also for the nuts?
Old Feb 7, 2018 | 10:24 AM
Pal215's Avatar
The FP turbo's come with two studs on the hot side of the turbo.
I used OEM hardware to mount my fp mani. Two long bolts from the Eclipse 4g63T with the factory spring washers and two manifold nuts. It's a tight fit, but it works if you slide the nuts on while you lower the manifold onto the studs. There is a certain angle where it's possible.
Old Feb 11, 2018 | 04:20 PM
EvoIIIAj's Avatar
Thanks. I ended up buying the ARP hardware listed and also 2 new OEM studs. I’m usingy MHI housing that I already have.
msterrorist
Sep 13, 2012 08:48 PM
lancer0220
For Sale - Wheels / Tires / Suspension / Brakes
Mar 11, 2011 05:19 AM
nightwalker
Sep 13, 2008 12:57 PM
AutoEuphoria
Apr 7, 2005 10:26 PM
