What mounting hardware for FP Manifold
Old Dec 2, 2014 | 10:53 AM
e_kobz's Avatar
To anyone who is running this manifold what hardware did you use to mount this to the turbo? Are you using FP's $60 hardware kit or did you come up with your own solution?
Thanks
Old Dec 2, 2014 | 11:32 AM
STLEVOIX's Avatar
http://www.streettunedmotorsports.co...p_bolt_kit.htm
Old Dec 2, 2014 | 12:04 PM
e_kobz's Avatar
I don't think those will work. The FP bolts are longer.
http://store.forcedperformance.net/m...Lancer-Exhaust
Old Dec 2, 2014 | 12:50 PM
STLEVOIX's Avatar
ok
Old Dec 3, 2014 | 11:53 AM
Fast_Freddie's Avatar
Veteran: Navy
All stuff was ordered from Jegs and drop shipped from ARP...
ARP 300-8343 Replacement Nut x2 Jegs PN 070-300-8343 $4.00
12-Point Nut
Black Oxide
M10 x 1.25 Small Collar
12mm Socket Size
1 per pkg
ARP 663-1010 Bulk Metric Thread Chromemoly Bolts 80mm(pack of 5) Jegs PN 070-663-1010 $18.22
Black Oxide
M10 x 1.25
80mm UHL
Subtotal: $26.22
FREE Handling: $0.00
FREE Shipping: $0.00
Total: $26.22
Old Dec 3, 2014 | 11:55 AM
e_kobz's Avatar
12-Point Nut
Black Oxide
12mm Socket Size
1 per pkg
Black Oxide
M10 x 1.25
80mm UHL
Subtotal: $26.22
Total: $26.22
Dammit I wish i saw this yesterday. I just gave in and ordered the FP hardware. Thanks for posting this. Hopefully this will help out people in the future.
Old Dec 3, 2014 | 12:02 PM
Veteran: Navy
I had posted it in another thread as well... also FYI the pack of 5 80mm bolts come with washers as well... so you can use 2 washers for the studs
Old Dec 3, 2014 | 12:03 PM
e_kobz's Avatar
I tried searching for this but I must have not seen your post. I wonder if FP will let me return it.
Old Dec 3, 2014 | 12:05 PM
Veteran: Navy
Perhaps, probably with a 20% restocking fee...
Old Dec 3, 2014 | 12:08 PM
e_kobz's Avatar
I would still be saving money. It cost me $72 for the hardware plus shipping.
Old Dec 3, 2014 | 12:44 PM
rich3389's Avatar
12-Point Nut
Black Oxide
12mm Socket Size
1 per pkg
Black Oxide
M10 x 1.25
80mm UHL
Subtotal: $26.22
Total: $26.22
It has been awhile since I took the turbo apart, does the turbo to manifold have 4 bolts in stock form, or 2 bolts and 2 studs?
Old Dec 3, 2014 | 03:52 PM
evo8426's Avatar
I bought two longer bolts, two nuts, and a few washers at a local store, didn't cost all that much and works the same.
Old Dec 4, 2014 | 06:50 AM
Veteran: Navy
2 bolts and 2 studs
Old Dec 6, 2014 | 06:33 AM
rich3389's Avatar
2 bolts and 2 studs
Thanks I ordered the ARP hardware you suggested .
Old Dec 7, 2014 | 05:52 PM
Veteran: Navy
No problem!
