how to fix leaky v-band flange ?
Old Dec 3, 2014 | 09:35 PM
stunt2's Avatar
Seems they are warped after welding and now causing exhaust leak no matter how much I tighten the clamp
Any fix for it ? Some thin multilayer gasket or something ?
Old Dec 5, 2014 | 10:35 AM
GravityKnight's Avatar
This is sadly quite common. best thing I have found is to take a hand grinder, with a brand new (flat stone). Has to be one where the nut that holds the stone on doesn't hang down lower than the stone (recessed). There is a bit of technique to it, but you have to run it around on the flange quickly and evenly. This works on all types of flanges that get warped after welding.
Old Dec 5, 2014 | 01:56 PM
240Z TwinTurbo's Avatar
Two things when using v-band flanges:
1) need to use a known good quality of SS material for the flange, such as 304
2) need to clamp the flanges to together in the as used configuration during welding, which will help prevent the flanges from warping. If you just weld the flange onto the pipe without having it clamped to the other flange it will warp.
Old Dec 5, 2014 | 01:59 PM
In your case you can search for v-band flange gasket.
http://store.034motorsport.com/v-ban...-gasket-3.html
Old Dec 5, 2014 | 05:04 PM
hutch959's Avatar
if they are just a little off... a fine coat of copper silicone on the mating joints will do it.
Old Dec 7, 2014 | 09:51 PM
stunt2's Avatar
they state:
Note, we do not recommend these gaskets on the turbo outlet, only when used sealing connections in the exhaust system.
then I've found this
http://www.ebay.com/itm/Stainless-Steel-High-Temp-V-band-Sealing-Gasket-3-/221382762543?pt=Motors_Car_Truck_Parts_Accessories&hash=item338b70e02f&vxp=mtr
Any good, anyone use it ?
Old Dec 8, 2014 | 07:04 AM
SWOLN's Avatar
a little OT, but does anyone make Titanium V-band flanges?
Old Dec 8, 2014 | 04:22 PM
Originally Posted by stunt2
they state:
Stainless Steel High Temp V Band Sealing Gasket 3" | eBay
You need a material that will compress. For $8 I would try the aluminum one, but if you can find them in copper then I would go with that. Stainless is a hard material and will not compress easily to create a seal.
Old Dec 9, 2014 | 01:53 AM
BkzProblem's Avatar
I've seen people wrap the flanges in aluminum foil and then clamp it. Idk if it works but its worth a try.
Silvermike
Mar 2, 2014 10:12 AM
brokenRS
Jan 4, 2010 08:50 PM
*02Lancer*
Lancer Aftermarket Forced Induction Tech
Nov 13, 2008 01:37 PM
HiHeatEVO
Jul 13, 2005 06:54 AM
