Taking care of my friends evo, need adivce.
Old Dec 8, 2014 | 11:41 PM
jnp1993's Avatar
Hi, my friend is outta country and I cant reach him. He is letting me take care of his evo 8 and its time for an oil change. I know standard is 10w 30 for stock engine, but it is modded. Which includes...
CBRD BBK turbo upgrade,1000cc PTE injectors, Mil-Spec rebuilt throttle body, Apexi intake, and a few more.
But since its modded, would I need to use a different weight oil, such as 5w 30, or 0w 40.
And I don't have a mitusbishi dealer around where I live, I cant get the oem filter, but is Mobil 1 filter just as good? I live in WA.
Old Dec 9, 2014 | 02:10 AM
R. Mutt's Avatar
10w30 should be fine. I live in Vancouver, BC which is reasonably close to WA and dd my car...plus we got snow last week. Unless you are seeing a lot of snow and really cold temps down there 10w should be fine. If it is freezing the lower weights are fine as well. If the car is sitting for long periods I recommend using something like amsoil zrod with a high zinc content. In general evos drive crappy when cold so let the car warm up at least until you see the needle get to AC before you set off.
Old Dec 9, 2014 | 11:33 AM
jnp1993's Avatar
Alright thanks I will use Mobil 10w 30. Do you also know if mobil 1 oil filter is any good compared to the oem one?
Old Dec 9, 2014 | 11:40 AM
ileakoil_mr's Avatar
wix is a great filter at a good price
Old Dec 14, 2014 | 07:55 AM
apagan01's Avatar
Amsoil zrod 10w30 will take care of your friends evo well... this oil wil take care of the car even when stored for winter.
Old Dec 15, 2014 | 06:03 PM
djmixerx's Avatar
I've used these filters and great prices.
Old Dec 16, 2014 | 09:19 AM
a few oem filters are just a wix rebranded i dont know about the mitsu but the mopar filters are. oem is all i prefer and avoid frams like they are the plague. they are known to be damaging to jeep motors for the lack of an anti drain back valve which cause you to essenstially start the motor without oil in the system
Old Dec 16, 2014 | 12:31 PM
wingless's Avatar
Take care to keep the RPM above 7k at all times. The clutch, front and rear diffs need special attention as well, use large slip angles, smokey low speed AWD burnouts + donuts to make sure they are working properly. The last thing you want is for your friend to think that you are not to be trusted with the care of his Evo!
jnp1993
Dec 11, 2014 07:36 PM
mi293806
Dec 5, 2013 03:34 PM
hotstix
19
Aug 16, 2011 09:51 PM
platinumspecv
Turbotrix Racing - Edison, NJ
Jan 20, 2005 11:14 AM
