Notchy shifting after new clutch ruining my fun..Any advice?
I had my clutch replaced in July with a Comp Stage 3 after my stock one started to slip. The flywheel was resurfaced and an OEM TOB was used. The transmission fluid was changed at the time with Amsoil MTG. I had a local Evo shop do the install. Prior to the new clutch the shifting was just fine.
The issue over the last few months has been that shifting is terribly notchy. It never grinds but it sometimes feels as if it is bouncing around in the shift gate to get into gear. It requires more pressure than before the clutch swap. Other times it kinda "pops" into gear. No gear is worse than the others. Low RPM driving is when it is the most difficult. Above 3500 RPMs it gets much easier to shift and at WOT its pretty buttery. Low speed (the majority of my daily driving) is a chore and it is quickly killing my fun with the car. I have tried bleeding the system, adjusting the clutch pedal, and installing a weighted knob. The shift knob was a a 300g Razo. It helped a bit but I still deal with some difficult shifting.
I have ordered a 490g BLOX and the bushing kit. Should I try replacing the fluid as well with Redline? Beyond that Im not sure what else to do. I don't have the time or capability to pull my transmission at the moment but i also don't want to ruin my tranny. I read another post from a guy using the Comp Stage 3 with exactly the same issues I have but it was never resolved.
Its just drivetrain movement. Every evo has this issue. There are several bushings you can swap that will help more than others. Its all over the forum if you search. I did front motor mount, driveshaft carrier, and differential mounts. I still need to do the tranny mount. These tighten it up pretty well but it gets noisy in the cabin.
It definitely shifts better when it gets warmed up but as I keep driving it can go from not too bad to pretty damn clunky especially at lower RPMs. I bled the clutch and adjusted the pedal to no avail.
I just had a comp stage 2 clutch and comp flywheel recently and had the same issue as you did. There was redline oil in the trans and I hated shifting in traffic because of this. I switched it back to oem fluid and it shifts like butter again in traffic and at high rpms. I say just stick to factory trans fluid and you will be ok.
If this issue turns out to be a clutch related issue I may just see how long it lasts and pickup another 5 speed to have rebuilt when and if the current one goes. The car has almost 100k and I really don't want to pay someone to pull off the tranny again to try to fix the issue on a clutch I do not like with my other drivetrain parts in questionable condition. I could spend $2800 or so and have the t-Case and tranny rebuilt and have an ACT HD installed as well. That would have to wait until the spring though.
Based on what you described I would bet on the pedal adjustment. I know you mentioned you adjusted it, but I would suggest doing that again. Try to go all the way to the end of the threaded shaft. if you are not all the way there yet its worth a try to see how it impacts your issue. Mine is nearly at the end, and common for HD clutch setups.
Well i finally bit the bullet and had an ACT HDSS clutch installed to replace the Comp Stage 3. The problem is not 100% gone but its soo much better. i actually enjoy driving the car again and the notchyness, when it rears it's head, is much reduced. I am pretty sure the Comp Stage 3 has worn my syncros but i still get no grinds. I plan on having Jack's Transmission rebuild the tranny whenever a syncro actually goes bad.
The moral of this story is to not over clutch your car with a 100k mile stock tranny.
CeeKayy
Aug 23, 2013 04:04 PM
detroit pistins
Nov 24, 2008 10:40 AM
SpyderTB
13
Apr 26, 2008 08:03 PM
apagan01
12
Mar 13, 2007 02:47 AM
watchout
Apr 3, 2005 05:52 PM
