Installed PTE 680cc injectors
I just installed a set of Presicion Turbo 680cc injectors for DSMs.
The web site sells them for $87 each
http://www.precisionte.com/products/...ectors+-+Mitsu
I got them from DSM incorporated on Ebay
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2466517128
The only thing I had to do is add 2 washers under the fuel rail (between rail and stock mounting spacer) because they were slightly longer.
Took about 30 minutes.
Instead of releasing the fuel pressure at the pump, under the back seat, I removed the Fuel Pump fuse in the engine compartment fuse box, (15amp at the rear left as you look from the front bumper). Then start the motor and let it die.
A little gas comes out. The clips on the injectors are tricky. Go slow.
Once installed it wa running way rich. I tuned with my Innovate WB O2 and Auterra Dynoscan datalogger.
I ended up pulling up to 23% at 7000.
Now I'm at 11.0 (+/- .2_ AFR) from 3000 to 7800.
Now I'm set for a new Buschur Turbo Kit!!!
I got these for $290 shipped. Best prices around.
Yes,those are the injectors made by "Rochester",usually found in G.M. production vehicles.Work well in dsm's and just need some tuning for in our Evo's.BTW,they have a nice spray pattern in comparison to "pintle seat" injectors.If I can find link I will show you.
scheides
May 28, 2015 12:01 PM
Anubis18
Apr 27, 2012 11:43 AM
taenaive
Aug 8, 2006 05:11 AM
