Car dies when MAF sensor is plugged in
Old May 19, 2015 | 10:56 AM
Tehjoser's Avatar
Originally Posted by llDemonll
did you replace the MAF?
Yes it been replaced same problem
Old May 29, 2015 | 09:13 AM
Tehjoser's Avatar
Well finally got her into with the professionals.(boostin performance)..
It came to be that the fuel pump was turning off intermittently
So it would shut the car off.
They Hard wired the fuel pump and she works as good as new.
Old Mar 21, 2018 | 11:31 AM
Evo43's Avatar
Having the same problem. Car(2010 GSR) is stock aside an AP which is set to a map that supports the Cobb air filter - it’s been like this for 3 years. I uninstalled the AP and reset the ECU - still not working. Car runs fine without the MAF plugged in. I replaced the MAF sensor and still shuts off only when plugged in. Have had 3 mechanics look at it and could not fix it. Had the fuel pump and wiring checked but no dice...The readings are way off in my AP, for example, the car reads it’s @ 3 rpms when the car is not even running and getting 3psi when boosting. The car does not feel like it has lost any power. I am at the Mitsubishi dealer replacing the ecu and that did not solve it. Mitsubishi can’t figure it out and about to give up. It’s been 2 months of trying to diagnose this thing. Any advice? Again, the car is currently bone stock.
Thanks
**UPDATE**
It ended up that some critters had chewed through some of the wires in the ECU's wiring harness. Took a long time to figure out but happy to get it fixed!
Old Feb 15, 2025 | 01:49 AM
Omarn22's Avatar
Good advice.thanks for updates. I had the exact same problem. I'll check the wires be
Thanks
**UPDATE**
MRadjahoe
Nov 30, 2012 04:25 PM
JDM EVO 6
Feb 10, 2012 08:10 PM
bnr34rb26dett
Nov 10, 2011 04:31 PM
93HardTopTurbo
Apr 26, 2009 02:11 PM
