Balance Shaft Install
Old Dec 28, 2014 | 02:07 PM
ReivaXVrai2's Avatar
I sent my engine off to Curt Brown to get a short block built, and I have received it back. I need to install the balance shafts, because I'm not doing a delete. I wasn't the one who pulled them, so I'm not sure how to install them. Now, I'm assuming I push them in and bolt them up, but is there anything I need to keep an eye on?
Old Dec 28, 2014 | 04:11 PM
robbyredneck's Avatar
on the oil pump side there are dots on the gears that need to be lined up. go to youtube and watch all of jafframobiles videos. great info there. i know he has a delete video but he also describes in detail the assembly process. intake side is just line the marks up and new belt.double check if the bearings are lined up. i highly doubt your builder would make that mistake but the piece of mind is worth it.
Old Dec 30, 2014 | 05:42 AM
Thank you so much!
Old Dec 31, 2014 | 12:51 AM
94AWDcoupe's Avatar
you will need to install bearings. this is one of the hardest jobs there is if you dont have the special tool. even good everyday mechanics will fail. if the bearings are hammered in they will be distorted and lead to near immediate failure.
boostawd16
Nov 20, 2013 04:47 AM
STIKiller4G63
10
Oct 2, 2012 07:44 AM
Anarchy99
11
Mar 7, 2012 12:17 PM
okevolutionVIII
33
Oct 30, 2011 08:05 PM
sterdyevo
12
Dec 8, 2007 12:08 PM
