Funny Idle
Old Mar 16, 2004 | 09:14 AM
Ev0 1's Avatar
Funny Idle
Ok, My car is stock. I have 21,000 miles on it and sometimes when i'm at a light it starts to idle either alil to high or sometimes alil low. What could be the problem?
Old Mar 16, 2004 | 09:20 AM
Mister2zx3's Avatar
Could be nothing.. what is a little high or a little low? hwo frequently and what's the ambiant temperature? And how long has the car been running?
Old Mar 16, 2004 | 10:07 AM
Ev0 1's Avatar
low like its about to stall out and high about up to the number 1. This happen every so often, it doesnt' matter how long I got the car running it could happen when i run it long or when i just recently started the car. Could it be the spark plug? or something misfiring?
Old Mar 16, 2004 | 10:34 AM
EvoJimbo's Avatar
You might have a vaccuum leak. Check all your hoses and clamp, make sure they are properly secured.
Old Mar 16, 2004 | 01:47 PM
Ev0 1's Avatar
ok thanks for the help imma go check it out now and tell you what i find.
Old Mar 16, 2004 | 01:52 PM
Ev0 1's Avatar
Old Mar 16, 2004 | 01:58 PM
ez76's Avatar
sometimes my car will do this periodically e.g. when i have the defroster or A/C on. i think it stands to reason that the car is compensating for the additional load?
nevertheless it couldn't hurt to check for vacuum leaks.
Old Mar 16, 2004 | 02:02 PM
the evo wins's Avatar
where exactly are teh vacuum lines because i have this problem too
Old Mar 16, 2004 | 03:02 PM
Ev0 1's Avatar
What am i suppose to see if there is a leak?
Old Jan 19, 2005 | 04:07 PM
KILTERMAN's Avatar
not to revive a dead thread but was wondering if this guy had fixed his problem. At signal lights today my idle was rising/ dropping anywhere from 500(near stall) to 1000rpm and it also had a very un-normal like sound while doing this. driving was fine and but the next light same thing, any opinion?
Old Jan 19, 2005 | 04:14 PM
UT_Evo's Avatar
Mine does it too, it's cold temperatures for me, the car's trying to get warmed up...ECUs arent as dumb as they want you to think
Old Jan 19, 2005 | 04:17 PM
KILTERMAN's Avatar
i had been driving for about 45 min , in warm 80 cali weather if this helps
Old Jan 19, 2005 | 04:21 PM
UT_Evo's Avatar
It's broken, trade it in for a civic
Old Jan 19, 2005 | 05:00 PM
KILTERMAN's Avatar
and your an asshat , trade your face in for my *******
Old Jan 19, 2005 | 06:52 PM
bpclements's Avatar
I have a similar problem that just started recently when the temps got really cold. I am convinced that it is a common thing with evos. It's prolly something to do with the turbo spooling down. The turbo is always spinning and when it spools down it doesn't move as much air which in turn cause the idle to richen up alot. I noticed my AFR's richen up to 12.0:1 or more. That rich condition will cause it to likely stall then idle high for a bit as the ecu tries to compensate. I know MalibuJack mentioned this exact same thing in another thread. This is the only answer that I could think off. I just put in new plugs and it still does it. I am getting new wires soon so I will see if that helps. I also have 39,000 miles on mine. Hope this helps.
BluEvo88
Jan 21, 2014 08:39 PM
Tanman1986
Jul 23, 2010 10:17 AM
mitsuboost30
ExtremeTurboSystems.com – WA
54
Jun 20, 2008 08:21 PM
Mark@AMS
Automotosports - Illinois
34
Sep 6, 2006 11:09 PM
Bom's Evo
Northeast Region
Dec 17, 2004 01:44 PM
