Evo fuel/boost cut...? Need help
Old Jan 14, 2015 | 07:59 AM
roger0416's Avatar
Hey guys so I got my Evo 8 a week ago. The last owner did not take the best care of it. I got the car and it had a fuel cut. So far I have changed the oil to Mobil 1 Extended performance 10w 30 (Many forums recommended it) and also changed the spark plugs(NGK BPR7ES gapped to about .26-.28). The Plugs were HORRIBLE after the car ran SOO much better. No fuel cuts or anything. However yesterday I stepped on it and hit a fuel cut again , my fuel was low so I filled up a bit and tried again, nothing. Hit fuel cuts again, so thinking it was crappy gas I added some octane booster... The car again ran amazing, pulled super hard thru 1,2,3 however in4th gear at around 6k RPM I hit a fuel cut ...
I'm thinking it might be a tuning problem...? Since the octane booster did seem to help. Also the car has some sort of Toyota(Denso) Coil in plugs on it, idk if that matters or if its normal.
I am new to Evo world and could use some expertise.
Thank you!
Old Jan 14, 2015 | 08:01 AM
thepoint4life23's Avatar
Many things to do first i would have the tune checked and put stock Coils back on
Old Jan 14, 2015 | 08:28 AM
roger0416's Avatar
Hmm, yea the tune is probably the most recent thing I'm going to do. I don't have the stock coils, any idea where I can get some? all the aftermarket ones online are super pricey.
Old Jan 14, 2015 | 10:35 AM
Ev0ikon's Avatar
Try 0.020" plug gap.
Old Jan 14, 2015 | 01:08 PM
roger0416's Avatar
Weird because I just tried the car today and it ran no problem , no fuel cut, not even deep into 7k rpms in 4th gear. Weird... Also if I smack the cold air filter ( the air intake in general) the car idles down. UI noticed this because every time I closed the hood the car idled down...
Well I'm not going to beat on it (or try to lol, just so much fun) until I re-gap the plugs to low 20s and get it tuned.
PS: I definitely appreciate all the help from you guys, thanks.
Old Jan 14, 2015 | 01:57 PM
Bhsj13's Avatar
what are your current modifications to your car? if you have a MBC and boost turned up without a tune it will cause those symptoms or modifications without a tune. you probably need a tune.
Old Jan 14, 2015 | 04:06 PM
roger0416's Avatar
From what Ive gathered so far
it has
Bigger FMIC
Injen Intake
Injen Charge pipe
Some sort of High flow catted exhaust (3 inch)
and it has the Toyota/Denso COP kit
Old Jan 14, 2015 | 07:20 PM
Bhsj13's Avatar
maybe it is your COP kit, was it a DIY one?
Old Jan 15, 2015 | 07:47 AM
roger0416's Avatar
It might be, it does look very clean and well done if it is.
Old Jan 15, 2015 | 08:06 AM
Ev0ikon's Avatar
Love those Toyota/Denso coils. They are fine.
Old Jan 15, 2015 | 08:57 AM
roger0416's Avatar
I've heard that from many people, lots of peeps say they're awesome and hold great power.
I'm just going wait and tune it, because when I add Octane booster the problem seems to almost go away so I am guessing its fuel/ timing related due to the tune.
13laqout
13
Nov 6, 2015 05:38 AM
eddy5201314
Aug 12, 2013 07:59 PM
erik.bouse
12
Dec 12, 2010 02:39 AM
Thugline
17
Apr 26, 2010 04:42 AM
ADMstunna
Apr 28, 2003 11:02 AM
