Opinions on valvesprings GSC or Kiggly...
Subscribe
Feb 13, 2015 | 09:35 AM
Quote: Yes. With that spring, the max RPM is 8200, with a max boost at 8200 of 25psi, with a GSC S2 camshaft.
Sorry, I should of specified my question better.
What is the reasoning to dictate max PSI? (spring tension?)
Who abides by this?
Reply 0
Feb 13, 2015 | 11:15 AM
Who abides by this?
Exceeding the max boost pressure can hold/push the valve open. And most people do abide by it, they just use stiffer springs. The GSC 5041's that are in my car are good for S3 or R2 cams to 10,500rpm and 44psi. Kiggly doesn't really list max rpm/boost because they don't know what cam you'll be using, but it's generally accepted that they can hold pretty much whatever you need them too, pretty much like the 5041's..
Reply 0
Feb 14, 2015 | 09:43 AM
Thank you sir
Reply 0
Subscribe
