Is this compressor surge??
Old Feb 19, 2015 | 08:34 AM
heliarcpro's Avatar
I have 3" turbo back exhaust, 3" intake, fmic. Battery relocation with small battery.
Old Feb 19, 2015 | 10:39 AM
thedru13's Avatar
Ok. Might want to start thinking about your next set up upgrades to support your turbo. You are going to max out your injectors if not already pretty quickly so hopefully you have a wideband in the car and also you will need something to be able to adjust the boost so either a MBC or an EBC. Just dont' want to drive 3 hours to get a tune and not be able to.
Turbo was the last part of my build since i wanted to max out the stock IX turbo.
but again pretty confident your BOV flutter issue will be resolved with the proper tune.
Old Feb 20, 2015 | 09:43 AM
heliarcpro's Avatar
Forgot to mention I have a MBC and wideband and I think stock injectors but don't know how to tell. What do stock injectors look like?
Old Feb 20, 2015 | 10:34 AM
thedru13's Avatar
You would have to remove one to check and see. your tuner will want to know what you have so they can safely tune the car.
Old Feb 21, 2015 | 03:46 PM
heliarcpro's Avatar
When I pull one what am I looking for to tell what size they are? If they are stock what size should I get to replace them? What brands are good?
Old Jun 24, 2015 | 12:37 PM
blackevolution8's Avatar
Ever figure this issue out?
Old Jun 29, 2015 | 11:39 AM
heliarcpro's Avatar
Yes the car needed a tune and the bov needed adjustment as well. I did the single spring mod on the bov which helped but not until I took it to get tuned did the problem get fixed totally.
ryukinevo
Nov 13, 2015 12:00 AM
jrblackSE
Sep 13, 2014 07:44 PM
boonkae
Mar 2, 2012 06:12 PM
AvatarOfWar
Apr 18, 2004 08:12 AM
Mad_SB
31
Jul 16, 2003 05:49 AM
