New to Evo 8 bought with milky oil
Old Mar 6, 2015 | 11:40 AM
  #31
kinein's Avatar
Originally Posted by Erik@MIL.SPEC
If you want a simple refresh, what you're talking about is not simple (156mm rods, etc).
Keeping it simple, you'd want to simply hone the bores, replace bearings and check for wear. You could put in a set of Weisco's and inexpensive H-beam rods and be done with it. I know Aby rebuilds his engines with OEM bearings, because they come in different sizes. And if you want to refresh the head with springs and retainers you can forget about, get the Kiggly beehive springs. They're pricy, but worth it. S2 is a good cam even for for an OEM turbo.
so basically hone the bores, replace bearings even with stock. Weisco's pistons with eagle or low end manley 150mm h-beam forged rods. Have the crank checked, I do want to refresh the heads with new cams s2 and springs. I think that covers it right? and obviously get it tuned afterwards.
so does it complicate things using 156mm rods?
now what about compression what compression should I be looking to get when I change out my pistons. higher then stock or lower to increase boost?
Old Mar 6, 2015 | 11:55 AM
  #32
Erik@MIL.SPEC's Avatar
Actually, I looked it up. I think you could run a 156mm rod with a stroker piston with the 88mm OEM crank, but I don't know if they make inexpensive H-beams in 156mm length. Perhaps they do. You can read this thread:
https://www.evolutionm.net/forums/ev...questions.html
Old Mar 6, 2015 | 02:09 PM
  #33
rongdoer's Avatar
I will be driving sometimes 600-1k miles a week.
You sure you don't want something that gets a little better gas mileage for that?
Old Mar 6, 2015 | 03:31 PM
  #34
jwongx27's Avatar
Yeah and something not super high mileage might not be reliable anymore.
Old Mar 6, 2015 | 07:48 PM
  #35
kinein's Avatar
for the gas mileage? nahhhhhh I have been driving that much already in my 993 every day like that with a heavy foot lucky if i get 250 miles per tank when its suppose to get me about 400miles. Its a 19 gallon gas tank.
Old Mar 6, 2015 | 07:50 PM
  #36
kinein's Avatar
I already starting prepping the motor to take the heads off and get those machine while I am doing the rest of the work to get the motor ready for rebuild. Might just pull the whole thing out.
Old Mar 7, 2015 | 06:48 AM
  #37
AreSTG's Avatar
Lol, you're going to hate the evo gas tank
Old Mar 8, 2015 | 05:48 PM
  #38
kinein's Avatar
Head is off heading over to the machine shop tomorrow. Need to start ordering parts. Took off 1 bearing and they look good for 215k miles. Need to finish cleaning the block to check for any warping.
Old Mar 10, 2015 | 05:40 PM
  #39
kinein's Avatar
well it seems I might have to pull the motor and do the block also. So I am contemplating buying a short block. What do you guys think? The cost of tearing down the block and then getting it hone and surface. then buy crank rods pistons and bearings. So I am thinking short block any input?
Old Mar 10, 2015 | 05:57 PM
  #40
jwongx27's Avatar
do the Core exchange program
where you send in your used short block with crank etc
they will send you a built one .
Old Mar 10, 2015 | 06:11 PM
  #41
kinein's Avatar
I am new to evo's who is a good source for that?
Old Mar 11, 2015 | 07:59 AM
  #42
jwongx27's Avatar
Depends on who you want to have do it.
Most cheapest and basic Build for a short block
its like 2.5k with a core exchange and
4.5k with out one
http://www.maperformance.com/maperfo...9-stage-1.html
then there is this one which is way better for power wise
https://secure.buschurracing.com/cat...d5bdc3b4bb7ce8
theres a few other companies that do the core exchange
evole97
14
Nov 10, 2021 08:06 AM
overdrive1
Apr 11, 2014 06:02 PM
izabran
22
Feb 3, 2012 10:32 AM
Evo8g23
Dec 30, 2011 12:54 PM
sdfontanini
10
Jul 14, 2009 09:44 PM
