horrible chatter when moving off
Old Mar 15, 2015 | 07:47 PM
dom4g63's Avatar
Hey guys my first post. Im trying to resolve an issue that i have been having for the pass couple of days.
Last month i changed my clutch to a clutch masters kit after the stock unit decide to die. After install the car drove fine and had no problems. Then one day i stopped in traffic on my way to work and when i went to move off the there was a violent chatter throughout the car, but it mainly felt like it was coming from the rear mainly. I assumed that it was the diff bushings causing the rear to move more than usual and when i checked they were shot. So i ordered a set and replaced them. And it didnt solve the issue.
Someone told me that it is my transfer case. But i have no whines not metallic noises and the problem only happens moving off going forward. The car reverses fine no chatter. Changing gears is fine and there is no chatter when i select and come off the clutch. the only problem i have sometimes is if i try to change gears fast it doesnt select i have to let the rpm drop low and gently put it in gear.
Has anyone had any similar problem?
I dont want to buy a transfer case if that is not likely the problem.
Old May 1, 2016 | 12:42 PM
matt1937's Avatar
check that the gearbox bolts are not backing out, also check that your engine mounts arent shot.
Old May 1, 2016 | 01:02 PM
kaj's Avatar
kaj
Did you put in a street disk or is it the puck type? Sprung or solid hub?
Old May 5, 2016 | 08:28 AM
GTijoejoe's Avatar
What about the flywheel?
Did you change it, or resurface it?
Did the car sit for any period of time?
Old May 6, 2016 | 04:09 AM
Bhsj13's Avatar
almost sounds like a warped flywheel
Old May 6, 2016 | 05:16 AM
CaptainSquirts's Avatar
Did you slip the clutch a lot recently? Maybe the flywheel/Pressure Plate could've gotten glazed. I've glazed my flywheel/PP a couple of times by slipping the clutch for to long and it basically is hard to grab when rolling from a stop but goes away in time.
Old May 9, 2016 | 02:10 AM
dom4g63's Avatar
the problem was exactly what matt said above. the gearbox bolts were backing out . I resolved few months back thanks.'
Old May 9, 2016 | 02:56 PM
D1andonlyantman's Avatar
Good man for replying, it's always better to have a finished thread
nick86green
Sep 28, 2011 05:30 PM
evo1981
Aug 17, 2011 07:32 PM
DoHBoY
Feb 21, 2008 09:53 AM
kreionic
May 18, 2006 02:08 PM
