HKS 264 and 272 mix setup
Old Mar 18, 2004 | 01:49 PM
TheeVOoNE's Avatar
I'm deciding on running aftermarket cams for my EVO and was wondering who is running this mix setup, HKS 264and272. Idling rough is not a concern to me but I'm wondering if the car stalls when approaching on and off traffic. I know the 272/272 setup does stall in traffic due to the character of being race cams, and that is the main reason why I'm not going to run it (unless this is not tue then I will be running them). Please provide me with some info. if possible. Also will I need retaining springs for the setup(264/272)? Any down fall for this the setup(264/272)?
Old Mar 18, 2004 | 01:58 PM
jj_008's Avatar
I have 272's and my car has not stalled once. I also have cam gears retard to -3 also.
Old Mar 18, 2004 | 04:10 PM
Shahul X's Avatar
is the -3 on the intake or exhaust cam? provide more power?
-shahul
Old Mar 18, 2004 | 08:18 PM
jj_008's Avatar
It is -3 on both sides. I am running the Vishnu Stage 1+ and that is what they recommend. I put the cams and gears in at the same time so I have no comparision if it provides more power. Vishnu claims they make a significant difference. It pulls real hard from about 3500rpms all the way through the redline. It idles like a big block V8 which is really cool. Vishnu has stated that the XEDE reflash can make them idle a little better, but I love the way they are now.
Old Mar 19, 2004 | 08:55 AM
l2r99gst's Avatar
If you are worried about stalling, just get cam gears and dial out some of the overlap of the cams. The increased overlap decreases the vacuum at idle, which causes the stalling problems. You can advance the exhaust cam or retard the intake cam to improve vacuum (decrease overlap).
FWIW, I run the 264/272 and I don't have any stalling problems.
Eric
Old Mar 19, 2004 | 09:15 AM
Shahul X's Avatar
are your cam gears made by HKS or Vishnu? and would the settings be the same... if they were Vishnu...how much were they?
Think Id be okay with the AFC, or need UTEC or Emanage?
-Shahul
Old Mar 19, 2004 | 09:25 AM
scottatyamaha's Avatar
Dont mean to take over your thread, but I am about to have my 26/272 HKS cams installed and I am not going to have any cam gears and have AL streeet tune it. Do you all think cam gears are neccasary?
Old Mar 19, 2004 | 09:38 AM
evo542's Avatar
no, they are not recomended for a street car, the turbo spools slower
Old Mar 19, 2004 | 09:40 AM
Shahul X's Avatar
if they can help the idle , then why wouldnt they be for a street car?
-Shahul
Old Mar 19, 2004 | 09:41 AM
evo542's Avatar
the turbo spools slower, so you lose torque (in the lower rpms of course)
Old Mar 19, 2004 | 09:46 AM
So just go ahead and get the cams installed and leave the cam gears stock?
Old Mar 19, 2004 | 10:19 AM
Shahul X's Avatar
I guess i'll try n cam gears 1st and then try the cam gears if I cant fix the idle via other avenues
-Shahul
Old Mar 19, 2004 | 12:23 PM
evo542's Avatar
that's what Al recomends
Old Mar 19, 2004 | 01:51 PM
jj_008's Avatar
I have the Vishnu cam gears which are a really nice piece. They have 5 lock bolts instead of 3 on the HKS.
As for losing low end torque, I would have to disagree. My car feels pretty strong every where on the powerband. I guess I could of lost some torque in the 2000-3000 rpm, but that isn't the powerband of the car.
Old Mar 19, 2004 | 02:07 PM
puckadog's Avatar
with my 264/272, sprockets(-3) my torque went from 285 (without cams) to 324. that's probably what you're feeling jj008
