EVO IX 71HTA CHRA w/ WGA
Old Apr 1, 2015 | 07:56 PM
ShanesEVO's Avatar
considering buying the HTA71. curious about how it was taking the hot side off of the oem turbo and putting the hta housing on.. has anyone done this themselves?
Old Apr 2, 2015 | 03:19 AM
slowsrt4:('s Avatar
Yes it was very easy to do. I had the 10.5 houtside and I really enjoyed this turbo
Old Apr 2, 2015 | 12:03 PM
Boost Demon's Avatar
Veteran: Air Force
Loosen the bolt that holds the "gold" colored collar that keeps the two halves of the turbo together and remove it. When you go to assemble the turbo, you'll notice one side of the turbo has a very small dowell like pin and the other side has a hole to receive it. This pin will ensure the turbo is positioned properly, so once you've got both halves oriented and mated together, bolt the collar back on and you're good. Drive to RRE for a tune.
Old Apr 2, 2015 | 12:17 PM
e_kobz's Avatar
Its a piece of cake to install. I did the entire swap in less than 4 hours without removing the hotside from the car or without unbolting the 02 housing or downpipe.
Old Apr 6, 2015 | 09:40 PM
ShanesEVO's Avatar
sweet thanks guys!
Old Apr 7, 2015 | 11:39 AM
LetsGetThisDone's Avatar
Some people won't be able to do that. From working on various Evo's, I've noticed that the vband clamp that holds the turbine housing to the CHRA is not in the same position on every car. I would recommend that guys buy new spring washers, and a new manifold to turbo gasket in case they need to pull the turbo. The O2 housing can stay on...
e_kobz
76
Nov 13, 2021 03:33 PM
mrm95
37
Jan 13, 2019 02:41 AM
Evo VIII 4o1
Mar 3, 2015 06:22 PM
Michael @ FP
11
Sep 27, 2014 01:38 PM
justin44
Feb 4, 2014 05:22 PM
