New evo low boost.
Old May 16, 2015 | 01:34 PM
EvoJimmy's Avatar
New evo low boost.
Just picked up my first evo and I've been slowly combing through it. The boost gauge wasn't hooked up but I could tell it was running on low boost. I fixed the boost gauge and indeed it's maxing out at a whooping 7psi!
So the wastegate vac hose is ran right to the turbo. I assume the stock spring rate is low and that's the cause of the problem.
I also assume there should be a stock boost controller between somewhere... Can someone help me out? My guess is I should just get a MBC a between the turbo and wastegate but I would like to know how I'm supposed to have it stock.... Just for informational purposes.
Old May 18, 2015 | 10:29 PM
EvoJimmy's Avatar
Can anyone confirm or deny stock wastegate spring pressure as .7bar/10psi?
Old May 19, 2015 | 06:12 AM
wilownu's Avatar
pretty sure the oem wastegate spring is ~11psi for an evo8.
Old May 19, 2015 | 06:40 PM
tegster1's Avatar
I'm at 11psi (evo 8) with just the wastegate pressure. Here is a link showing the vacuum line hookup for the stock boost control solenoid. Looking from the front it is at the bottom right under the air filter. 2 vaccum lines and a connector.
https://www.evolutionm.net/forums/ev...-solenoid.html
Old May 20, 2015 | 10:33 PM
EvoJimmy's Avatar
Thank you for that!
It seems my gf has ordered a new hallman for Father's Day so hopefully ill be back at atleast stock evo boost here shortly. I feel like I'm driving a stock GSX currently haha.
Old Jun 2, 2015 | 07:09 PM
tegster1's Avatar
Good luck. Hopefully you get it all sorted out and able to run the normal 18psi or so.
Old Jun 2, 2015 | 09:04 PM
EvoJimmy's Avatar
Thanks man I have the hallman in and im running 18-19psi nicely. Checked the turbo for shaft play when installing the MBC and it feels good.
I really let her rip last night on my way home and good lord does it sound good at WOT.
LancerShop.com
Lancer Vendor Classifieds
Oct 27, 2016 06:25 PM
SoCalRedLine
Jun 19, 2013 09:40 AM
speedfreak24
Feb 15, 2010 08:35 PM
Show Off
Feb 25, 2008 10:52 AM
JSC Speed
Oct 26, 2005 07:40 AM
