Valve Stem to Guide Clearance Question
Old May 19, 2015 | 12:17 PM
bostonhatcher's Avatar
Hey guys I just finished my LR2.4 build. After 200 miles I started experiencing smoking on high rpm decel. Pulled the plugs and noticed oil on top of the pistons.
I had my local machinist rebuild the head during the build process and he said the guide to stem clearance was within spec. I personally installed the OEM stem seals with the plastic tool from euro export. I made sure the viton seals were on the exhaust side. Before I installed my Kiggly beehives I checked to see how much side to side play there was between the valve and guide and there was zero play.
After seeing the oil on top of the pistons I pulled the valve cover and none of the stems have popped off. How is so much oil getting on top of the pistons with brand new valve stem seals and zero play between the valve and guide? The valves and guides were not replaced when my machinist rebuilt the head and have about 30,000 miles on them. My compression is between 185-195 psi.
Old May 20, 2015 | 11:36 AM
WikdEvo's Avatar
What is your ring gap and ptw clearance? If it's only under Decel id think rings. When under boost they will swell up and create a better seal. Under vacuum.. Not so much.
Old May 20, 2015 | 08:06 PM
Bad rings will smoke all the time and will not build oil on top of the Pistons. Ptw is .0035" and top ring is .015" and second ring is .018".
Old May 20, 2015 | 09:36 PM
barneyb's Avatar
Bad rings will smoke on deceleration. Bad valve seals will smoke on startup.
Old May 20, 2015 | 09:45 PM
WikdEvo's Avatar
Your clearances sound very very tight... What Pistons? This may be your issue.
Old May 21, 2015 | 06:07 AM
Wiseco 1400HD
ChicagoEvo9
Jul 16, 2013 01:51 PM
baggelis
22
May 1, 2013 06:54 AM
Aby@MIL.SPEC
Feb 4, 2008 08:42 AM
