Piston/ Valve Damage
Old Jun 7, 2015 | 08:05 PM
88888's Avatar
Exclamation Piston/ Valve Damage
I had zero compression on cylinder 1.
Took the head apart and turns out that i have a bent intake valve on cylinder one. spark plugs were in one piece and car gets spark/fuel.
Timing is all good and other three cylinders have full compression.
oil and coolant level/ color look good.
cylinder walls look healthy.
Damage can be seen as attached.
my question is.
- i will obviously be redoing the valves but is piston replacement necessary?
- what risks would i be running into by keeping the same piston?
any comments would be appreciated!!
Attached Thumbnails Piston/ Valve Damage-unnamed.jpg   Piston/ Valve Damage-unnamed-1-.jpg
Old Jun 8, 2015 | 04:27 AM
kelvinTME's Avatar
So what was bouncing around in the cylinder to create all the surface damage???
Old Jun 8, 2015 | 05:07 AM
Ausevo7's Avatar
Any damage to the bore?
Old Jun 8, 2015 | 09:39 AM
LetsGetThisDone's Avatar
I would replace that. The piston has taken a beating. Also, all those little pits can hotspots on the piston surface, which can cause knock/detonation..
Old Jun 9, 2015 | 06:06 AM
88888's Avatar
it looks like it was caused by detonation
no damage to the bore
hmm thanks for your input
Old Jun 9, 2015 | 07:32 AM
mrfred's Avatar
all the indents on the head don't look like det. i wonder if the damage on the piston face can be minimized by polishing.
Old Jun 9, 2015 | 08:49 AM
Its definitely not detonation, something got in there. That something probably also bent the valve when the valve tried to close on it, the valve did not hit the piston. Detonation creates a lot more, much smaller pits, and its generally around the outside of the crown piston
KaranS94
May 19, 2018 12:43 PM
stunt2
Jun 8, 2014 08:27 PM
TommiM
13
Jun 12, 2011 10:59 PM
kkarim
Feb 11, 2008 05:40 PM
gofaster87
Jan 8, 2007 03:30 PM
