Timing belt tensioner/bearing failures
Old Jun 12, 2015 | 12:39 PM
meckert's Avatar
Curious-- while there are several thread on timing belt noise, I haven't seen any posting on component failures-- bearings, tensioners. Here's what happened, swapped timing belt tensioner and all bears with OEM equipment from the dealer 40k ago. Never and issue, no weird noises, belt has always remained tensioned--correctly I have assumed, when belt is pressed between cam shaft pulleys, maybe 1/4-1/2 in of play. So anyway, pulled off the timing cover and pulled belt--seems all bearings are shot, all wobble, all lost grease, tensioner shot. Been around cars 40years and have never seen anything like this--. Anyone else seeing this from OE parts--several of you have used after market components-- and maybe I should have too.Anyone else see this with OEM timing components? Call me crazy but I expect 60k service to well, last 60K?
Old Jun 12, 2015 | 01:04 PM
LetsGetThisDone's Avatar
My '05 only has 42k miles, but I replaced the belt and hydraulic tensioner at 20k miles since they were almost 10 years. All the factory pulleys are still going strong..
Old Jun 12, 2015 | 08:58 PM
barneyb's Avatar
That seems odd. Did you or someone else do the service?
Old Jun 13, 2015 | 08:15 AM
meckert's Avatar
I bought the parts and did the service-- I find it strange as well. I can understand a bearing going out every now and then--but every piece has an issue.
SLVRNBLK
Mar 21, 2016 05:51 PM
APM Racing
Midwest Region
Jan 31, 2014 03:13 PM
Blue91lx
May 16, 2012 08:35 AM
Robertv34
Aug 27, 2011 12:55 PM
nightwalker
Mar 11, 2007 08:24 PM
