IACV and idle issues
Old Jul 4, 2015 | 08:09 AM
asu11's Avatar
So currently trying to diagnose a rough idle on my IX. Car was just tuned by Tscomp so the tune is not the issue.
The car currently idles around 1300 with ac off and threw a P0507 code last night: Idle Air Control (IAC) System RPM Higher Than Expected
Idle is set at 1000 in ECU.
If im driving and just push the clutch in to come to a stop, the rpms will drop and then start bouncing up and down between 900-1400 until it finds a happy point, then it will idle high(1300). This is even worse with the ac on. It has died on occasion, but post tune it has not died yet.
I pulled my IACV and it ohmed out OK. All test points about 30ohms. I also checked the volatge at the connector(top and bottom center), and they both show 12V so I know its getting correct power.
I also unplugged the battery for a few mins and reconnected. No change.
Here's the guide I used for voltage and resistance checks: http://www.lancerregister.com/faq_f22.php
the IACV does not act like this video:
It simply just buzzes and does not move in and out.
I have 2 different IACV's that both ohm out OK but exhibit the same issue.
The car was cold when I tested, so not sure if that would make a difference. My understanding is it does some type of stroke check when you turn ignition to the ON position.
I boost leak tested last week and everything was OK, but I will check again this week when I get a chance. Ill also get with Tom to see if he can figure anything out tune wise.
Im going to try and order this IACV to see how it works:
http://www.ebay.com/itm/MD628318-Idle-Air-Control-Valve-Fits-Chrysler-Dodge-Mitsubishi-/191225823452?hash=item2c85f280dc&vxp=mtr
I know I should get OEM, but I dont want to spend 3xx bucks until I know the part is this issue.
The throttle body was also recently rebuilt about a year ago and still looks very clean.
I know a lot of people have had this issue, but I didn't see alot of fixes in my searches. Hopefully we can get some good info and a fix.
Anyone have any ideas?
Old Jul 4, 2015 | 08:24 AM
asu11's Avatar
So I took off negative battery cable and reconnected and tested it with it connected and it did a normal stroke check like that video.
I tired a 2nd and 3rd time and it did not. Maybe that's normal?
Yojimbo
Oct 2, 2014 04:49 PM
NattyMyst1c
Apr 11, 2012 11:46 PM
hyeteck
Sep 10, 2011 07:39 PM
korndogg
Apr 9, 2010 08:10 PM
