Bad Turbo?
Old Jul 13, 2015 | 06:32 AM
wannaevo1X's Avatar
Bad Turbo?
I have a stock 8 Turbo on my car running that has been running 28psi for the past 15K miles. Turbo has 40k miles on it. It currently will peak to only 24psi then fall to about 18psi. Did a boost leak test and found a small leak by the TB but could this be causing the loss of 4psi? Also the turbo spins very free, but if I check for shaft play and try to spin it, the wheel feels like it binds with not much pressure added. What should my next step be?
Old Jul 13, 2015 | 04:11 PM
LetsGetThisDone's Avatar
Fix the boost leak, if it doesn't fix it, then see about your turbo.
Old Jul 13, 2015 | 04:36 PM
llDemonll's Avatar
stock turbos wont hold until redline.
perfectly normal
Old Jul 13, 2015 | 04:38 PM
perfectly normal
The issue is that his peak boost is down 4psi from where it was tuned. There is an issue present..
Old Jul 14, 2015 | 07:56 AM
llDemonll's Avatar
missed those two numbers. replace the seals (or whatever is leaking), they're a common leak-point on most all evos. and yes, any leaks will affect things. the more pressure added the faster the leak will bleed off pressure. 4psi wouldn't be abnormal at all
Ferraritech
24
Apr 4, 2014 12:03 PM
jaxjoker
Northwest Region
Jul 17, 2003 12:55 PM
