Low Boost with EBC
Old Mar 22, 2004 | 08:54 AM
raywong's Avatar
Low Boost with EBC
My boost max out at 1.35bar(19.5psi) with the boost control knob turned all the way to max position. Is it the limited of the stock turbo or is there something wrong with my car?
Old Mar 22, 2004 | 11:33 AM
GTVEVO's Avatar
Did you buy pass the factory sylinoid and cap it off?
Old Mar 22, 2004 | 08:15 PM
raywong's Avatar
I did bypass the factory solenoid.
Should I try different spring in the Forge BOV?
Old Mar 22, 2004 | 08:22 PM
evo542's Avatar
what ebc are you using, i know the g-reddy BspecII sucks at holding boost
Old Mar 22, 2004 | 08:23 PM
GTVEVO's Avatar
My next question is how do you have the wastegate hooked up. Is it hooked up on the release side from the EBC sylinoid? Or is it hooked up on a T line to the input side of the EBC sylinoid? If it is hooked up on the line in side you could be loosing pressure the entire time since it flaps up at about 11psi. This would be the next question I ask so if this isn't it I would say that the EBC sylinoid is running the correct duty due to it being bad or still hooked up incorrectly.
Old Mar 22, 2004 | 11:13 PM
raywong's Avatar
I am using a HKS EVC EZii, it simply has a power switch, knob A and knob B.
I am not too sure how it is setup, will check again later.
MR. EVO MR
Sep 29, 2009 06:03 PM
Western_man
Sep 25, 2008 11:20 PM
justchil
24
Jul 20, 2006 04:09 AM
megatron
11
Dec 14, 2005 06:46 PM
Jinu0808
Oct 6, 2003 05:05 PM
