New front case, new oil pump, leak from seal
So we got my buddy's car started tonight. Brand new curt brown 2.3l, new front case, new oil pump, balance shafts removed. Car started and was running. We were letting it warm up to check for leaks. After about 5 min of idling, there was a small leak from the bottom of the timing cover. So I took everything off to inspect.
The seal on the oil pump shaft is leaking....this is a brand new oem part with 5 min of runtime. The pump shaft had no play that I could tell, no metal around as if the pump shaft was trying to walk around. I don't understand how a new pump with new seals and all can just start leaking.
Any ideas?
Any ideas?
dueces
May 17, 2017 04:24 PM
ProPilot04
14
Oct 5, 2015 02:47 PM
fortyPSIrs
Feb 1, 2013 09:34 AM
RunThat
Dec 22, 2008 12:33 PM
aspensvt16
Aug 10, 2008 04:35 PM
