New Front Case/Oil Pump oil leak. Need Help!
Old May 9, 2017 | 06:54 AM
dueces's Avatar
Hi guys, I haven't been on here in years, since I sold my first Evo. Now I have another, and I just built a 2.3L, and while everything is back together and I have started it, I have found a large oil leak.
The leak is coming down the case right behind the Crankshaft Position Sensor, so I started to research it and people were saying the center bolt on the Motor Mount needs sealant since it hits an oil galley, so that was the first thing I did.
After letting the thread sealant sit for 24 hours, I started the motor last night and it still has the same oil leak. This is a HUGE oil leak. It leaks 2-3 drops of the front case every second.
So I wiped everything clean, again, and there is no oil above the front case at all. There is what looks like a check valve on the top of the front case, and that is where I think the leak is coming from. This "ball" is directly above the oil pump shaft.
Does anyone have any experience with this leaking? What are my options? I thought about having a friend lay a weld bead to cover the hole, but I don't know if that would have any ill effects.
Any help would be greatly appreciated! Thanks guys,
John
Attached Thumbnails New Front Case/Oil Pump oil leak. Need Help!-evo-8-oil-pump-front-case.png
Old May 13, 2017 | 10:45 PM
Jersey Dino's Avatar
John
did you remove your balance shaft? If so, that bolt hole needs to be plugged where the previous assembly went. Good luck
Old May 17, 2017 | 04:24 PM
kpr's Avatar
kpr
Usually its the castle nut. Did it have a good o-ring, was it tightened enough? Did you put lock-tight on it to be sure it wont leak?
tsidrift1
Jul 28, 2015 08:57 AM
fortyPSIrs
Feb 1, 2013 09:34 AM
Turbo01s2k
10
Jan 16, 2013 06:36 AM
ActofDuty
Nov 3, 2009 07:30 PM
Blacksheepdj
Lancer Troubleshooting
Mar 31, 2005 08:44 AM
