New Throttle Body - Idles High - Tune or Screw adjustment?
Old Aug 12, 2015 | 06:27 PM
llDemonll's Avatar
What's the best way to adjust a high idle after throttle body swap? Rebuilt throttle body from Mil.Spec so I'm not concerned with it leaking, my old one was pretty beat up and tuned for that "beat-up-ness"
I'm guessing getting the idle tuned to normal would be the best way to go about fixing this?
Old Aug 12, 2015 | 07:12 PM
kpr's Avatar
kpr
you need to follow the service manual procedures. Just search TPS adjustment. Set the TPS then unplug the IACV and set idle to ~850
Old Aug 13, 2015 | 07:44 AM
llDemonll's Avatar
pending the TPS is already set (Aby @ Mil.Spec says he configures them) this should just mean unplug IACV, set idle to 850, plug in IACV and good to go...
guess we'll find out tomorrow!
Old Aug 16, 2015 | 08:51 AM
lostsoulsevo's Avatar
Check for boost leaks first. If everything checks out you can adjust the bliss screw. Just make sure the actuator is on in evoscan before you make any adjustments.
Old Aug 17, 2015 | 08:54 AM
llDemonll's Avatar
<p>IACV is dead. Would also explain idle hunting sometimes (1000-1500 rpm 2-3 times occasionally when coming to a stop)</p><p>&nbsp;</p><p>Tried cleaning the current one, etc. etc. &nbsp;Car idles exactly the same with it unplugged as when it's plugged in. &nbsp;New one in the mail soon!</p>
evoforlife
Jan 23, 2011 10:05 AM
lancer02es
Lancer Engine Management / Tuning Forums
10
Sep 23, 2007 02:57 AM
p911t
Lancer Engine Tech
11
Jun 10, 2002 07:10 AM
