Radiator fan for half rad setup
Old Aug 27, 2015 | 04:57 PM
nismo3183's Avatar
Switching over to a half rad, forward facing setup and would like to know peoples opinions on which rad/fan combo is good to go with. Car is not a daily and it gets hot and humid in the summer in NJ so I'm looking for something that can cope with NJ climate. I wanted to go with a Koyo half rad but I am open to suggestions at this point if someone has a better option. I would really like to go with a fan shroud setup if possible too.
Old Aug 30, 2015 | 08:03 AM
nismo3183's Avatar
seriously....no responses??
Old Aug 30, 2015 | 09:05 AM
420a-t's Avatar
I went with the mishimoto radiator and used my stock fan. Doesn't get any more simple than that. The stock fan moves a ton of air and is already shrouded. Yes, it may be a little heavier, but a few pounds vs cooling issues is a no brainer for me.
I just did a 1/2 mile even and coolant Temps stayed in check even with it being in the 90s
Old Aug 30, 2015 | 11:23 AM
XSilverJ's Avatar
Koyo half rad and stock fan here.. KISS imo
Old Aug 30, 2015 | 01:17 PM
nismo3183's Avatar
What about driving around town or better yet stop and go? I know many shops have a disclaimer stating half rad setups are pretty much designed for racing but I see so many people using them that I am wondering if this is true. Car isn't my daily but I'm just trying to get a feel for what the limitations of the setup are.
Old Aug 30, 2015 | 11:11 PM
MyronGainz's Avatar
I ran half rad for some time, but wasn't comfortable with how long it was taking my car to shed the heat in ~100+ temperatures. I was literally cycling the OEM fan on for a little while with only a couple seconds break in stop/go traffic.
Went back to full size after that
Old Aug 31, 2015 | 12:07 AM
deylag's Avatar
Here is what I found. There are definitely better options than the stock fan available.
https://www.evolutionm.net/forums/ve...torsports.html
https://www.evolutionm.net/forums/ev...-header-3.html
Old Aug 31, 2015 | 07:28 AM
SmurfZilla's Avatar
Using a Koyo and a SPAL/FAL fan that moves 1400CFM and has a shroud. Probably overkill. I'd have a CBRD radiator if my last one didnt melt down with the Evo that burned down.
Old Aug 31, 2015 | 12:15 PM
nismo3183's Avatar
Overkill is good when you have a half radiator setup. Did you purchase the fan/shroud combo or made a shroud?
Old Nov 24, 2015 | 07:00 AM
luisderoux's Avatar
Yes indeed!
I started with a smallish fan that pushed tons of air but was not doing the job, almost overheating.
I installed a FAL 123 :
https://www.flex-a-lite.com/electric...ctric-fan.html
We are in Panama were sh...t gets HOT; this baby moves air like its feeding ice to my radiator.
tasevo
Jul 20, 2014 05:49 PM
Ricekiller81
11
Sep 9, 2013 10:52 AM
mblaster890
10
Aug 30, 2012 09:54 PM
Nesiop
Nov 15, 2011 08:21 AM
sktng22
Oct 26, 2011 02:23 PM
