Front drive shaft issues
Old Sep 21, 2015 | 05:35 AM
JGNERAEVO9's Avatar
Front drive shaft won't lock in place it's JDM so usdm drivers side. It's in there loose now and trying to avoid full turning lock to avoid leaks. Any reason why they wouldn't lock. I had and old tcase lying around and it goes straight in.
Old Sep 21, 2015 | 03:35 PM
JGNERAEVO9's Avatar
Bump
Old Sep 21, 2015 | 03:37 PM
LetsGetThisDone's Avatar
Is the stub shaft missing either of the hog rings?
Old Sep 22, 2015 | 02:03 AM
JGNERAEVO9's Avatar
Yeah everything is still there.
Old Sep 22, 2015 | 08:15 AM
Try replacing the hog rings...
Old Sep 23, 2015 | 07:13 AM
JGNERAEVO9's Avatar
Nothing wrong with the hog rings what so ever.
Old Sep 23, 2015 | 07:19 AM
03whitegsr's Avatar
The c-clips lose their tension and usually stop holding in the axle after being in and out a couple times. It's good practice to just replace them each time the axle comes out.
Old Sep 23, 2015 | 08:04 AM
This
Old Sep 23, 2015 | 08:13 AM
JGNERAEVO9's Avatar
Yes but like I said the shaft went straight into another transfer case I have.
Old Sep 23, 2015 | 10:35 AM
It shouldn't go straight in. You should have to wack it in with a dead blow (plastic) hammer.
Evokid03
20
Mar 5, 2010 12:22 PM
mrblob20
Dec 26, 2006 07:47 PM
