Hey, i have messing now with the 4g63T engine about 2weeks and still no glue where the oil is leaking. Parts with covered oil is Transfer box and oil pan, the head cover and the intake manifold, and a small amount of oil is on the under the turbo, gearbox and engine attach point. Changed so far is oil pan ( victor reinz seal ), exhaust manifold gasket, head cover gasket, oil pressure switch ( not new, just seal ). The Oil cap and oil level stick is correctly in place.
Greetings From Estonia !
I suppose you should pressure/power wash the engine after spraying some de-greaser to get as much of the oil off, then run it for a short while and see which general area it's coming from.
I've never pressure washed an engine, and would be conscious of the electricals in there, so do some research before doing that, but first getting rid of the existing oil is the best way of finding the source.
Have done the power wash + brake clean all, and done it repeatedly. Same result. ( 3km run to get the result in pics ) Just done the oil pressure switch seal again and some oil pan nuts retorque. Let seal to dry and start it again tomarrow. What a big headache.
Iam sure its engine oil, need to refill pretty fast. New valve cover gasket driven about 500km only . The leak is only hard driving and extreme leak with launch control.
Where I see oil in your first picture is around the dip stick tube and suspect that it is the source.
This---looks like your blowing the dig stick up-and spraying oil all over. A common issue. Clean PCV valve and hope that's it. Or its a blow by issue, that will require some kind of catch can/s to remedy. GL
Okey, now on test drive i noticed blue smoke ( oil ) rear of my car only on deaccerlatin after full boost. PCV valve open ? PCV valve issiue explains the oil stick leak too. no smoke on idle or usual drive, only after full boost. ( letting throttle off, no clutching ) Ordered today new oil pressure switch and hoping that will fix the leak.
EDIT : My Bov is extremly hard and surges the turbo hard. can it be to surge goes to valve cover and burts oil into intake manifold ?
Interesting as I have an evo 4 engine in my 8 and have a very similar problem. I know mine is not the dipstick. I think it is the valve cover gasket. I haven't replaced that yet. The other reason I think that's it is because the top of the flange on my intake manifold will collect a bit of oil over a few hard runs and then I think its dripping down the back of the engine.
You may want to check/replace the pcv too. Mine is currently blocked off.
That BOV needs to be replaced. You don't want compressor surge, it will ruin your turbo.
worked full day with engine today. Result is not so good. Power wash whole engine and replaced bov to subaru sti bypass and went to hard run on gravel. Runs good and power is ok. But after full boost is blue smoke still. And after run is covered with oil under the turbo section and transfer box and oil pan, The upper part of the engine is now dry. I think ill take the oil pan again off and try to seal it the third time. But what about that smoke ? PCV ? Turbo ? ( i hope it isnt, its from evo IX )
Did you replace the cam seals and half moon? I had some on my eclipse that would shoot oil out only under boost and after I replaced those it was all good. Good luck, the blue smoke may be the turbo seals going bad or you may have way too much crank case pressure and causing too much oil to go in the intake system which gets burned in the engine.
