evo ix intake
Old Oct 6, 2015 | 08:08 PM
Ebs's Avatar
Ebs
evo ix intake
so i am new to the evo community and i was looking for some advise on cold air intake systems. i currently have a k and n filter system and was wondering if i should stay with k and n or move to a different one. my ix is currently stock with the exception of intake and exhaust. thanks in advance
Old Oct 7, 2015 | 05:26 AM
Speedlimit's Avatar
Admin Emeritus
Hi and welcome!
You're not new any more! I'm going to move your post to the Evo forum, there you will have a better chance of getting your questions answered. Thanks!
Bob
Old Oct 7, 2015 | 05:44 AM
ronaldo9's Avatar
What are your goals? I'd just leave it alone since there are better mods you can do. Do you plan on going speed density in the future or you staying with a maf setup? You won't gain much from changing it as they are all more or less the same. My $.02.
Old Oct 7, 2015 | 06:05 AM
Ebs's Avatar
Ebs
I'd like to do speed density, but don't you have to tune it to that?
Old Oct 7, 2015 | 08:06 AM
ronaldo9's Avatar
If you plan on going speed density then you most definitely will need to retune your car. You will also have a lot of options as far as what filter and piping you want to run.
Old Oct 7, 2015 | 05:36 PM
Bhsj13's Avatar
just keep it. SD is not really a must if maf is fine.
Old Oct 7, 2015 | 06:56 PM
Ebs's Avatar
Ebs
In the long run if I was planning on putting 500 whp then would getting SD be worth it?
Old Oct 8, 2015 | 05:13 AM
evo8426's Avatar
You will be buying an aftermarket turbo for that goal and likely won't stick with an intake designed for OEM turbo.
Old Oct 8, 2015 | 05:10 PM
Ebs's Avatar
Ebs
Ok that makes sense. Thanks for the information.
Old Oct 8, 2015 | 08:53 PM
e30_pilot's Avatar
im in the same boat as you. I just have a drop in filter. If you'll looking to get a new turbo, I would just hold off on the intake for now until you decide to get a bigger turbo. That way you dont go buying two different intake setups, if that makes since
Old Oct 9, 2015 | 03:40 PM
Ebs's Avatar
Ebs
Yeah it's makin a lot more sense to wait and get the turbo first.
david200095367
Feb 25, 2014 05:10 PM
jameelrose
Jun 2, 2013 03:15 AM
migwel
18
Mar 23, 2011 08:09 PM
shadow1
Apr 15, 2010 11:38 PM
chaotichoax
Jun 4, 2009 07:55 AM
