Fan causing idling issues
Old Oct 21, 2015 | 11:40 AM
Jptanada's Avatar
Hey guys, I finally decided to ask you guys for some help. It's been bugging me more and more. I don't drive my Evo that much but I guess I'll finally address my issue:
my fan randomly turns on and off it seems to suck power causing idling issues. Especially when I just turn on the car the fan will kick on a few seconds and off. Few seconds later again it will turn on then off. When I'm in the car and when the fan kicks on I can see my dash lights dim a bit and the engine will idle below 1k making it shudder. Has anyone else have had this problem before? I already got a new battery and sparkplugs. I did some research and someone had a similar issue but no one responded to it. The thread was dated 2009 so I thought I would just ask. Thanks!!
Old Oct 21, 2015 | 12:25 PM
Ev0ikon's Avatar
When did you do the last boost leak test?
Old Oct 21, 2015 | 01:31 PM
wreckleford's Avatar
Stock injectors or upgraded? I've seen injector latency issues cause this. When the fan kicks in the voltage drops for a split second and due to the latency value at 11 volts being wrong the idle dips for a bit due to a momentary lean condition.
It will also happen if your IAC is bad but you should notice other ill effects also.
Old Oct 24, 2015 | 03:23 PM
Turndown's Avatar
Veteran: Army
Do you have the air on in the car when it does this?
dorian7
Dec 22, 2008 09:36 PM
JWhat89
Lancer Engine Tech
10
Oct 29, 2008 07:21 PM
Sixspeed J
Jul 18, 2008 08:37 AM
Inprogress
May 8, 2008 03:43 PM
EVO-genetik
Lancer Engine Tech
Jul 4, 2006 05:51 PM
