evo 9 engine stalls when you push clutch in
Old Oct 23, 2015 | 08:23 AM
MLucas13's Avatar
it all started slowly. first it stalled once a month and i really didn't notice it then it started to stall more and more in till now it stall every time i push the clutch in. if i gave it gas it would stay running but now it dosn't even do that because now once it warms up it back fires and the engine sucks the rpms down and shuts off.
things i have tried.
-boost leak test
-replaced the seals in throttle body
-adjusting throttle position
i just had the block built but back to stock again. i believe the problem could be the thrust bearing but not totally sure. just wondering if anyone else had any ideas for me to check before i pull the motor.
Old Oct 23, 2015 | 09:25 AM
evo8426's Avatar
Possible that the ISCV could be failing. A quick search should help you find how to test.
Old Oct 23, 2015 | 09:30 AM
barneyb's Avatar
Check the crankshaft end play.
Old Oct 23, 2015 | 12:31 PM
94AWDcoupe's Avatar
this
Old Oct 23, 2015 | 06:31 PM
maknuge's Avatar
Originally Posted by 94AWDcoupe
this
This times two. Check the play in the crank. Could be the dreaded crank walk. Although it's more prone to happen in dsm cars, there has been cases in the evo world. Put a pry bar on the crank and check in and out play
evotris
25
Jun 2, 2014 09:27 PM
detroit pistins
13
Dec 19, 2013 10:43 PM
ArchieBabes
14
Jul 10, 2011 10:01 AM
Boost3dxEvO
Aug 25, 2009 07:15 PM
olschool
14
Apr 4, 2006 07:56 PM
