Needing some advice for my DD
You can pull the cams and have the specs checked, but I would just leave them in there and get it tuned. Your bolt-ons plus a good tune (maybe E85 lol) will make for a fun car.
As far as the motor mounts, I installed a Blox front motor mount and the others are stock. It was a very nice improvement over stock and I haven't noticed any noise increase.
And I can see that whole "stock" thing. I consider my Ralliart "mostly stock" even though I have a parts and mod list as long as my arm...
You should drop the pan and take a look, you might find another surprise.
Im realizing that I have almost everything I need to go speed density at this point. I really only have to figure out how to wire in the IAT sensor now. My wife bought me the Omni-Power 4 bar MAP sensor for christmas. So I am getting very tempted to, instead of going back to stock, make use of everything I have and just getting it tuned well somewhere.
So what put the stubby shaft in the oil pump, and just leave the rear shaft in place? does that not cause any issues with it still supplying oil to those bearings and nothing moving? I kinda feel like that would be a problem since your not blocking off those unused oil passages.
Just talk to whoever will be tuning the car(if you picked someone already) and see what they have to say. I didnt wire an IAT sensor when I went SD.
SpoolinUp also sells a couple variations of IAT harnesses, maybe check that out.
http://www.spoolinup.com/Evo-Speed-D...ness_p_74.html
Here is some info about the balance shafts
http://www.jackstransmissions.com/pa...balance-shafts
i chose to just leave the shaft in and not run the belt.
also, in regards to the IAT sensor, a tuner can also use the fuel temp sensor if you're not wanting to do the wiring, etc. Some tuners like to use one, some the other. they both seem to work pretty well.
Good deal I will remember that. Thanks kaj!
Got the head pulled off of the engine Sunday night. Going to be stripping it down and getting it to a machine shop soon. However I noticed this once I got the head off. From what I am seeing these are supposed to be Evo 8 pistons right? Since the car is a 9 Im assuming this engine has been rebuilt at some point now...
Thanks evo8tanner!
I do have a question today. I have the head back from the shop and I have it put back together. However I noticed last night that the Mivec cam gear has some slack in it or something. it will twist two teeth back and make a gurgling sound, but the cam itself does not move. It doesnt go any further than that, nor does anything appear to be loose. Did the shop reassemble something incorrectly? Or is it supposed to do that?
Thanks for any quick answers. I am hoping to get the engine assembled today if everything is ok.
So far the only other road block I am dealing with is rebuilding my turbo. I have the compressor off but the dang hot side will not let go of the center section. Ive tried penetrating oils, heating it up, pulling on it, tapping it with a rubber mallet... idk... :/
Freshly Rebuilt Head
Posted more pics over in my Show-N-Shine thread. Found HERE didnt want to spam with a bunch of pics.
broke a few pieces tonight. and after seeing how worn the timing belts really were i got paranoid and decided to go ahead and do the balance shaft delete and to replace all the timing pulleys. Placed an order for those, and the necessary gaskets. Also picked up the Kiggly Racing HLA.
Finally got my turbo apart tonight too. So that rebuild will be next on my plate. Noticed the O2 housing had a nice crack half way around it so I will be trying to seal it up with some JB Weld. If that doesn't work it'll give me a good excuse to get a screamer pipe or a hood dump.
