no power to fuel pump or injector?
Old Nov 30, 2015 | 03:09 PM
CNOEVO22's Avatar
so i killed my car about a month ago pulling into the garage, and tried to start it up again but no go. the car cranks like it wants to start but no juice. i checked the power to the fuel pump and there wasent any, so i figured maybe crank sensor went bad. i did a little looking and found that if i was getting spark that shouldnt be the case, and im getting spark. so i replaced the main mfi relay, and the resistors on the fire wall and still nothing. so im thinking maybe the immobilizer did something funny but i cant get into it with ecuflash to shut it off. any ideas how to get into my ecu, or anyother ideas why im not getting any power to the fuel pump or injectors.
Old Dec 1, 2015 | 09:38 AM
LetsGetThisDone's Avatar
Fuel pump only gets power when cranking. Are you checking power at the pump while someone is cranking the engine?
Power to injectors is likely a fuse or other wiring issue, the injectors should always have power when the key is on, the ECU only controls the ground.
Old Dec 1, 2015 | 09:45 AM
IzzyRS's Avatar
Did you do a good visual check of all the fuses?
Old Dec 2, 2015 | 05:12 AM
CNOEVO22's Avatar
I'll check when cranking and I pulled each fuse and checked them. Thanks for the ideas I also tested each relay
rickspecd
11
Sep 29, 2014 08:28 AM
rickspecd
EvoX 'For Sale' External Engine / Power
11
Sep 29, 2014 08:27 AM
Carloverx
14
Dec 22, 2011 01:00 PM
Octane Blue
Mar 28, 2011 09:07 AM
