400HP Evo 9. Stock turbo?
Old Feb 18, 2016 | 12:11 PM
LetsGetThisDone's Avatar
You want the CHRA upgrade, not the whole turbo. I posted a link in this thread....
Old Feb 18, 2016 | 01:13 PM
soderdna's Avatar
Duuuuuuh lol I'm an idiot. Thanks man
Old Feb 18, 2016 | 07:30 PM
3gturbo's Avatar
You'll still need to find a 10.5cm evo 8.5/9 turbine housing.
As far as 71hta vs 20g. Idk about max power. But I know the 71hta kills it in boost threshold.
Whats the difference between this and the old school journal bearing green?
Old Feb 18, 2016 | 07:36 PM
3gturbo's Avatar
Nm found the answer the green is a bit bigger at a 73hta
Originally Posted by rockbmx1 View Post
I just spoke with Robert at fp and he said it's 51lbs/min and it spools up pretty close to stock. He said he's making this turbo to help out the low budget Evo owners and offer a budget quality turbo. Thanks fp.
Old Feb 18, 2016 | 09:14 PM
e30_pilot's Avatar
Originally Posted by e_kobz
I did 403whp on my IX at 25psi on crappy 91. Cams would make even more. Probably 415 to 425whp depending on fuel. I have a set of mivec S1's for sale if you're interested. Would be a perfect suit for this turbo
What mods did you have? I'm stuck on 9, no e85 around me.
Old Feb 18, 2016 | 10:13 PM
e_kobz's Avatar
Mods are in my signature
Old Feb 18, 2016 | 10:32 PM
e30_pilot's Avatar
Oops. I'm on mobile so I can't see it lol but I'll get on my work computer tomorrow
Old Feb 19, 2016 | 03:04 AM
kaj's Avatar
kaj
Check the new post feed. There is another thread re: the hta71.
Short version = I made 350whp on 91oct/26psi and a small cam. Not much else. 400whp on e85.
I'm not sure how people are getting 400whp on 91. It usually takes an FP Red to do that.
Old Feb 19, 2016 | 05:00 AM
e_kobz's Avatar
I made almost 352whp with the stock turbo, stock cams, and bolt-ons's on 91 at 25psi. I went on to make 398whp on E85 at 28psi with the same mods. The 71hta bumped my up about 50whp on both 91 and E85.
Old Feb 19, 2016 | 05:21 AM
soderdna's Avatar
Would a COP setup and switching to speed density help make up the 30-40 hp difference to get to 400?
Old Feb 19, 2016 | 05:24 AM
e_kobz's Avatar
Speed Density on a stock turbo won't net you much. Not really worth it on anything smaller than a Red in my opinion. COP won't net you much either. Both of those mods are for improved drive ability, not making power even though they will make a couple extra here and there.
Old Feb 19, 2016 | 05:28 AM
e_kobz's Avatar
Just went over your mod list, you need a 3 port boost controller. Stock is holding you back, especially if you say it's maxed at only 18psi. It seems you're being tuned on a mustang dyno. There called heart breakers for a reason. You will never see a stock turbo do 400whp on a mustang on pump gas.
Old Feb 19, 2016 | 05:32 AM
soderdna's Avatar
Yes i understand that. Dynojet numbers are 322 AWHP. I am definitely going to get a boost controller although I'm undecided to going manual or going full out with ecu boost control. Do you think it's worth it to get a 3port and 4bar map sensor?
Factory BCS is maxed at 18psi although I spike higher than that especially now that it's cold. Wastegate can't keep up lol
Old Feb 19, 2016 | 05:46 AM
soderdna's Avatar
Thanks for clearing that up. I'm definitely considering the cop kit just because I've heard it is a night and day difference on driveability. Speed density doesn't seem like it's worth it on a stock turbo
Old Feb 19, 2016 | 07:18 AM
saxon's Avatar
speed density is IMO a must have for these cars, it will pick up power and the driveability is significantly better IMO
with my stock longblock evo 9 and bolt ons i made 339whp on a mustang dyno, would be near impossible to hit 400whp on pump gas and honestly hard to hit that with race gas on a mustang dyno.
