View Poll Results: Which Balance Shaft Do you run or plan on running?
OEM Mitsubishi Stubby Shaft
21
42.86%
AMS Race Shaft
4.08%
GSC Race Shaft
16.33%
Magnus Stubby Shaft
0%
Stock Balance Shaft
18
36.73%
Voters: 49. You may not vote on this poll
Evo Balance Shaft Thread
I own a JDM evo. All JDM evos 1-9 as far as i am aware run balance shafts and i've taken my fair few of them apart.
Stock Evo 9 block and crank, but upgraded long rods and buschur spec pistons. Car made well over 900hp and had upgraded motor mounts so there was a decent amount of vibrations. But that stuff is pretty normal for that power level. I was revving car to 9500 rpms. Hope that helps. It was still completely a street car and that’s the only place I drove it
The stiffer motor mounts will transfer a lot more vibration. Did you notice in a certain RPM range additional added vibration other than just the motor mounts would transfer ?
Here's how I got my stuck crank bolt out. Not my video but my results were identical.
https://www.youtube.com/watch?v=LtVZrqh4zXw
Will you be deleting both Balance shafts now to compare since you got the bolt out?
BS delete for me in my former EVO IV and my new build. I reckon that Mitsubishi's engineers surely put the BS in for a reason, but as we rebuild the engine all the rotating assembly components will weight differently from the OEM ones, thus changing the frequency from the OEM rotating assembly.
My tuner/builder has every engine without BS and no issues in any race or street car.
The only time that an engine vibrated too much was with a 2.3L Manley Crank (Only crank changed due spun bearing and welded flywheel). It was incredible how much vibration that crank added.
boostawd16
Nov 20, 2013 04:47 AM
STIKiller4G63
10
Oct 2, 2012 07:44 AM
Anarchy99
11
Mar 7, 2012 12:17 PM
okevolutionVIII
33
Oct 30, 2011 08:05 PM
sterdyevo
12
Dec 8, 2007 12:08 PM
