Built Setup Details ADVISE NEEDED
Old Feb 20, 2016 | 11:59 PM
Mr Evo-8's Avatar
Hello Evolutionm members,
I would like to share my setup selection with you guys and before ordering it, I for sure will be considering experience/knowledge of you guys.
your help will be appreciated.
1. Balance Shaft Removal Kit
2. Manley 4G63/4G64 Turbo Tuff Rods (ARP 2000) (Evo 8/9 & 7-Bolt*
3. OEM Timing Belt Kit & Water Pump (Evo VIII) 4. Fluidampr Crank Pulley
5. OEM Evo Front Case / Oil Pump and Gasket
6. ARP 'L19' Head Studs Evo VIII-IX
7. ACL Rod Bearings (Standard with Extra Oil Clearance) 8. ACL Main Bearings (Standard)
9. ACL Thrust Washer Set
10. OEM Evo Engine Gasket Kit
11. AEM EVO VIII cam gears
12. Torque Solution 4-Piece Race Motor Mount Kit
13. Energy Suspension Evo VIII-IX Hyper-Flex Complete Bushing Set. 14. Gates Accessory Belt Evo
15. Quarter Master Evo VIII-IX 8-Leg Street Clutch Kit (wth 5-Speed HRB)
16. STM Master to Slave Clutch Line for QM 5-Speed HRB (Evo VIII-IX)
17. Torque Solution Short Shifter Evo VIII-IX 5-Speed
18. Torque Solution Shifter Base Bushing Kit Evo VII-IX
19. Torque Solution Carrier Bearing Support Bushings DSM/Evo
20. Energy Suspension Evo VIII-IX Rear Diff/Moustache Bushing 21. TiAL Q Blow Off Valve (Aluminum Weld Flange)
Spring: 6 psi
22.ETS 4" intercooler kit
23.Garrett GTw3884r 67mm t4 twinscroll 1.00 ar w/ 3" discharge
24.ETS T4 Twin Wastge manifold Front Mount.
25. magnus Intake Manifold with s90 Throttle Body
26.Fuel System with -8/-10 lines from rear to fuel rail ( including rail, ID 2000 Injectors,regulator, pumps and mounts
28.Hawk Pads and D2 Drag racing spec ( Swift Spring ) coilvers 29. Koyo Half Radiator w/ slim fan Cooling/Radiator 30. Aem S1
31. Turbosmart Compgate 40mm WG's
32. Quaife Front LSD Differential
33. Driven Breakin oil 5w30 ( 15qts )
34. NGK iridium Spark plugs +2 BKReIX
35. Redline Shockproof 75-90 Transmission Fluid
36. ARP mainstud kit Evo 8
head is built already.
I have given all the details, (Some might not be important) but thought of sharing it completing. Advise on the Clutch, Throttle body combo and coilovers to be on top.
Car is for street racing. Pump gas with Meth injection.
jameswwt
11
Feb 2, 2016 07:44 AM
yellowbirds58
May 12, 2013 08:16 AM
dhahlen
Jan 9, 2009 11:08 PM
Gsxfury
For Sale - Cars For Sale
42
Dec 9, 2007 09:09 AM
KZEVO
Jun 9, 2007 08:09 AM
